Mini Cooper 2006: Central Locking & Windows Issue - Door Auto-Close/Open, Passenger Window
wdx 6495 1
  • #1 17046356
    wdx
    The problem occurs periodically from winter. After entering the car or switching off the ignition, the door automatically closes and opens. This process stops when a / starts the engine b / stops by itself (in the closed position). Once there was a brief opening and closing (2 cm) of the passenger window.
    I have not found a similar described ailment. Anyone have any suspicions where to look for the cause?
  • #2 17046732
    Pedros050
    Help: 2471
    Rate: 3927
    Hello. The defect must be looked for in the installation of the front driver's door, can there be tarnished contacts connecting the door installation with the passenger pillar? It doesn't hurt to remove the rubber cover and check if there is a broken ground or power cable?
