Title: Troubleshooting SSD Drive for Client: Blue Screen Errors, System Repair & Testing Tools
theded 5664 1
  • #1 17046934
    theded
    Rate: 62
    I sold a new SSD drive to the client. After a week, the customer rings that the system has sprinkled. Actually, windows crashes blue screen with some error, the attempt to repair fails. Access to the data was but the system repair from the disc also did not go. Interestingly, it happened unexpectedly, windows updates turned off, so that's not it. The client has turned off the computer, after restarting the windows, he gave a mistake and did not start.
    I do this with HDD: I run MHDD, I check smart, I do a surface test. As it is ok, I assume that the disk is functional. How to do it with an SSD drive? Smart is ok, surface test too (made mhdd). I downloaded some SSD benchmark and correct results. Some disk state evaluation software shows that the disk is healthy. Can I still check somehow? I do not want to give the client a drive to be the same in a week.
  • #2 17046982
    Kasek21
    Help: 4981
    Rate: 3547
    SSD Life what shows?
    MHDD is not suitable for SSDs.
    What was there for the error - maybe it is not the fault of the drive only its hardware / driver / system?
