Cabasse Tronic Radio: Connecting AUX Socket - Step-by-Step Guide & Compatibility
radko911 17508 7
  • #1 17050770
    radko911
    Hello to all forum users.
    I have a question about the Cabasse Tronic radio.
    Namely, the question is whether it is possible to connect to this type of radio AUX socket?
    • Cabasse Tronic Radio: Connecting AUX Socket - Step-by-Step Guide & Compatibility DSC_0810.JPG (1.38 MB) You must be logged in to download this attachment.
    • Cabasse Tronic Radio: Connecting AUX Socket - Step-by-Step Guide & Compatibility DSC_0809.JPG (7.48 MB) You must be logged in to download this attachment.
    • Cabasse Tronic Radio: Connecting AUX Socket - Step-by-Step Guide & Compatibility DSC_0808.JPG (7.67 MB) You must be logged in to download this attachment.
  • #2 17052625
    djlj24
    Car audio specialist
    Help: 1104
    Rate: 1327
    First, determine whether you have the AUX option in the settings menu. If you find one then chances are. Only I would be interested in the receiver module, which you probably have under the passenger seat, because what you showed in the picture is a disc changer.
  • #3 17052717
    radko911
    There is no option to select aux in the settings
    There is only radio / cd on the steering wheel
  • #4 17161776
    goryczka
    Were you able to find a way to connect the AUX?
  • #5 17200775
    amdek
    on this radio the aux is activated by giving a voltage of 12v a yellow ISO mini plug on pin 5 or 6 I don't remember :) but then the Aux output will appear on the radio
  • #6 17201546
    goryczka
    I mean, which pins need to be connected? It looks like this to me
    • Cabasse Tronic Radio: Connecting AUX Socket - Step-by-Step Guide & Compatibility 20180410_205656.jpg (768.5 KB) You must be logged in to download this attachment.
    • Cabasse Tronic Radio: Connecting AUX Socket - Step-by-Step Guide & Compatibility 20180410_205705.jpg (604.28 KB) You must be logged in to download this attachment.
  • #7 17320180
    radko911
    Someone overwhelmed this connection
The discussion revolves around the possibility of connecting an AUX socket to the Cabasse Tronic radio. Users initially explore the settings menu for an AUX option, but it is confirmed that there is no such feature available. A solution is proposed where activating the AUX function requires applying 12V to a specific pin (5 or 6) on a yellow ISO mini plug, which will then enable the AUX output on the radio. Additional resources are shared for further guidance on the connection process.
