Laguna 2 PH2 Cabasse Tronic: Identifying Speaker Outputs, Grounds, +12V, Remote Out Pins
Usatysfakcjonowany12 9666 3
  • #1 16524274
    Hello, I have a problem because I have a rather unusual factory radio of the Lagoon 2 and I would like to know what way you have to find out or maybe someone knows under which pins in the cube are the outputs from the loudspeakers and exactly what masses, + 12V, remote out.
    Laguna 2 PH2 Cabasse Tronic: Identifying Speaker Outputs, Grounds, +12V, Remote Out Pins Laguna 2 PH2 Cabasse Tronic: Identifying Speaker Outputs, Grounds, +12V, Remote Out Pins Laguna 2 PH2 Cabasse Tronic: Identifying Speaker Outputs, Grounds, +12V, Remote Out Pins
  • #2 16524325
    piwko
    Help: 87
    Rate: 214
    The problem is, it's not a radio. It's just a cd player, the tuner is in the trunk.
  • #3 16525444
    I have the middle of my receiver here, which are the pins from the speakers and exactly what, ground, + 12V, remote out.
  • #4 20870465
    mazurekpiotr26
    >>16524325
    The receiver can also be in the glove box, as it is in my case, and there are regular ISO cubes connected to it.
