Activating AUX on Blaupunkt Travelpilot E1 Radio with ISO Cube Connection
Topeczek 10245 3
  • Asking how to activate AUX on Travelpilot E1
    #1 16652869
    Topeczek
    I warmly welcome.
    I have an AUX cable with an ISO cube and when I connect it to the radio, nothing happens.
    And here's the problem. How do I activate AUX for it to work? Is there a way to do this?
    I add photos of the radio and the schematic :)
    Activating AUX on Blaupunkt Travelpilot E1 Radio with ISO Cube Connection Activating AUX on Blaupunkt Travelpilot E1 Radio with ISO Cube Connection Activating AUX on Blaupunkt Travelpilot E1 Radio with ISO Cube Connection
  • #2 16652949
    płetwa
    Help: 165
    Rate: 556
    There is no way to do it, the radio does not have an audio line input.
  • #3 17531462
    diesell76
    I have tried pn cd changer 8-pin input but no sucsess.... it needs data communication with changer to see it is present ..... I think you can do it on the telephone input .... you just have to figure how to add mute switch .... and you have stereo input
  • #4 18433036
    diesell76
    Activating AUX on Blaupunkt Travelpilot E1 Radio with ISO Cube Connection Activating AUX on Blaupunkt Travelpilot E1 Radio with ISO Cube Connection Activating AUX on Blaupunkt Travelpilot E1 Radio with ISO Cube Connection Activating AUX on Blaupunkt Travelpilot E1 Radio with ISO Cube Connection
    Blaupunkt travelpilot e1
    Using telephone input jus separating mono in into stereo and putting away echo effect... So just using preampl section of this blaupunkt chip.. But to switch to telephone you need switch from tel mute to earth. Also dont forget to turn telephone aux off.. Radio will not switch off automatically... It will drain your battery😁
    The sound is exellent👍
    This is the only way that you can add aux to this radio....
