BAXI Duotec Compact + Boiler: Unwanted Heating of Radiators & Nighttime Activation Issues
Staszek8483 15960 17
Why does my Baxi Duo-tec Compact+ boiler heat the radiators when I switch on domestic hot water, and why does it sometimes turn on at night even though the room thermostat is off?
The nighttime self-starts were most likely caused by the SALUS 091FLRF(TX) wireless thermostat using the factory/default code, so changing the code with the jumpers in both the transmitter and receiver stopped the problem [#17060397][#17072271] The radiators heating while you draw hot water usually points to a faulty three-way valve in a combi boiler, so that valve should be checked first [#17062268][#17076563] One user with a Baxi also solved unwanted heat flow into the heating circuit by installing a check valve on the heating circuit [#17182262]
  • #1 17057576
    Staszek8483
    Rate: 8
    Hello everyone.
    I have been using the BAXI Duotec Compact + boiler for 4 months. It serves me hot and cold water
    The problem is that when I heat water, my radiators start to heat up. I have a room thermostat (controller) connected to a boiler that regulates my temperature in the house and when the temperature in the house is adequate, it turns off the heating, and if I want to heat the water, e.g. for bathing, the radiators get hot.
    The service technician has been with us several times, says that the boiler is ok, finally replaced the stirrer, it did not help, also replaced the filter, the problem, unfortunately, still occurs. Anyone had a similar problem?
    The second thing - for two days the boiler turns itself on at night and the radiators start to heat, I checked the room controller, the temperature is ok, as it is to be set at night and the controller shows that the stove should not heat and the flame on the stove that heats and temperature 30 degrees, all radiators warm. I turned off the boiler for the night. In the morning I turned on the boiler and the controller started working to heat the temperature in the house and the boiler heated the water in radiators to 30 degrees, radiators cold. I called a service technician and said it was either a dirty filter or a wrong filter was installed, i.e. the gas filter was installed in place of the water filter and the boiler was going crazy and the room controller would not work either. I called the plumber, he arrived, he checked the filter was clean and it was a water filter. Once again to the service technician but he will be until Monday.
    I don't know what's going on anymore. Are these boilers just emergency and it was a bad purchase and it will go on forever, or maybe I have it all mounted incorrectly and the service technician does not know what's going on?
    Please help if anyone had a similar problem.
  • #2 17058592
    dobroslaw
    Help: 57
    Rate: 157
    Only good factory service will work here, the cauldrons are so new that not everything is known about them yet, what kind of controller you have on off or with type and sense or baxi communication, whether you have an external temperature sensor, where the controller is plugged in.
    Term Klima serwis De Dietrich Białystok
    białystok słowackiego 7, Białystok, 15-229 | Tel.: 500XXXXXX (Show)
  • #3 17058843
    Staszek8483
    Rate: 8
    you ask about the controller which is on the boiler?
    I don't have an external sensor.
    As for the service, there are two servicemen in my area, one comes and tries to do something but I still have problems with the boiler, the other said that he could come see but if it was not the boiler's fault I would pay 700 PLN for diagnostics, I also stayed with one service technician.
    You wrote that these are new boilers, it is possible that service technicians do not know it yet and really do not know where the problem is?
    Because a few times when there was a service technician, I heard "now it will be good" and unfortunately it is not.
    Added after 26 [minutes]:
    The boiler just turned on, as it did late in the evening, and heats up to 30-35 degrees. The room thermostat is currently set for the night, standby because the temperature in the house is right and the transmitter connected to the boiler caught a signal because the LED is green. Room thermostat mam wireless SALUS model 091FLRF (TX)
    Added after 48 [seconds]:
    Maybe that's the problem with this room thermostat?
  • #4 17060397
    dobroslaw
    Help: 57
    Rate: 157
    Change the address of this salus with jumpers (the same combination in the transmitter and receiver) certainly the neighbor next door has the same and also factory settings and you change the common cause :)
  • #5 17060642
    slider2002
    Help: 10
    Rate: 43
    I used to have it with my auraton. We have all our guests in the block because it was included in the package from the developer. There were also miracles before we put various codes.
  • #6 17062268
    BUCKS
    Help: 536
    Rate: 1086
    [...] when I want to heat the water, e.g. for bathing, the radiators get hot. [...]
    So how do you heat dhw, and the boiler heats radiators, and if a service technician comes, is it OK?
    Do you have a stratified tank, do you only heat domestic hot water without a tank?
    I do not know Baxi boilers but in 2-function boilers there is usually a plate heat exchanger that heats the hot water and the symptom you are writing about usually means a problem with a three-way valve.
    In this situation, the maximum capacity of domestic hot water also decreases, so in the absence of a tank and at high flows you would have unheated tap water.
    As for automatic boiler activation, as colleagues wrote, this Salus model has an analogue code selection for transmitter and receiver cooperation, so the neighbor transmitter will control each receiver in range with an identically set code. In addition, the relatively large range means that in extreme situations your boiler can be controlled even by someone from the block next to you if the buildings are close together.
  • #7 17072271
    Staszek8483
    Rate: 8
    Thank you for advice.
    I changed the code in the transmitter and receiver, I watch the boiler from Sunday and everything is ok, it does not turn on.
    Added after 53 [minutes]:
    No, when a service technician arrives, there is a problem all the time. It fixes something, changes something and the problem with heating radiators is all the time.
    I have a heat pump, the boiler at these temperatures heats my hot water, tank 270 liters.
    I will tell the service technician that this may be a problem with the three-way valve.
  • #8 17075731
    BUCKS
    Help: 536
    Rate: 1086
    I'd rather change a service technician if he doesn't know what's going on, unless you pay nothing for these tests and they don't have the effect of exchange, it will go away in the crowd.
    But you never know what it is exchanging or for, whether it is a full-fledged product or a defective product, and always if something is working, it's better to have a factory one.
    Staszek8483 wrote:
    270 liter tank.
    If you have a layered tank with such capacity, you may not feel a decrease in boiler efficiency, because with instantaneous heating you would have a noticeable decrease felt on your own skin.
    As an amateur I would check this valve first. The construction of a 2-function boiler is relatively simple and there is no space technology there, so accurate diagnosis should be quick. The more I am surprised that the alleged service technician does not know what to do and makes random exchanges that do not bring improvement. For me, it's a hacker, not a service technician.
  • #9 17076161
    palala
    Help: 59
    Rate: 105
    Maybe from the beginning. I am not a specialist in the subject, but I have such questions:
    How do you solve the storage tank next to the 2-function boiler?
    How is the storage heater (legionella) set?
    In the manual of the boiler which has one circuit which is to remain open for cooling after heating the domestic hot water (1-F boiler).
    Regards
  • #10 17076344
    Staszek8483
    Rate: 8
    [Quote = "BUCKS"]
    As I wrote earlier, I have two service technicians in the region, one said on the phone that he can come and check the boiler, but if it turns out good, the diagnosis will be 700 PLN for payment, and how will I know what he checked there ?? The one who comes to me does everything for free under the warranty, the last time he had to change something was waiting for part 2 weeks, I hope he ordered the original part and therefore such waiting time.
    Added after 9 [minutes]:
    Regards
    I do not know much about this and I do not understand the question "How do you have the storage tank next to a 2-function boiler?"
    As for legionella, it was also a small problem at the beginning because the service technician set us up once a week and the boiler heated the container every evening, I had to disconnect it, I ordered the service technician to completely turn off the legionella and now I set it myself manually and I do it when I want the legionella. As it will be a little warmer and the pump will work, I have the legionella programmed automatically there.
  • #11 17076495
    BUCKS
    Help: 536
    Rate: 1086
    Staszek8483 wrote:
    As I wrote earlier, there are two service technicians in my region, one said on the phone that he can come and check the boiler, but if it turns out that it is good, for diagnosis PLN 700 will be paid
    As the boiler is under warranty, there is no such thing as PLN 700 for diagnostics. That is, a smart serviceman.
    Since the heaters heaters when heating hot water, the boiler is not functional.
    In addition, a second service technician replaces parts, but cannot repair the fault.
    For me weird, either you have a wacky guy for 700 PLN or some loser who replaces parts for free, although nothing improves it.
    Maybe in the end, if this loser replaces the entire boiler in parts for a new one, it will start working properly.
    Unless you have a fucked up installation, and the contractor was the one who now exchanges parts for you and looks for what he screwed up.
    On the other hand, since you have a 2-function boiler, I am surprised by a 270-liter stratified tank. I would sooner expect 100 liters, because larger volumes fit more to a tank with a coil, etc.
    Either you have enormous consumption of hot tap water or you have mixed up something and it is a little different than it appears from your description.
    Either way, no one from the forum can solve it.
    You got suggestions, you still have to do it with a service technician but all signs indicate that you have a poor service technician and the other one is a smart, so you don't know which is better.
  • #12 17076541
    Staszek8483
    Rate: 8
    Tank I have with a coil, heat pump galmet 270 l.
    I do not have much hot water consumption
    I know that no one from the forum will solve this problem for me, but I thought that maybe someone had such a problem and his service technician repaired it for him, because if I see my service technician and his inept attempts to fix it, I would like to help him and give him a hint.
  • #13 17076563
    BUCKS
    Help: 536
    Rate: 1086
    And these are the differences.
    As you wrote earlier, I understood that for heating you have a heat pump, and for hot water you use a gas boiler + tank.
    On the other hand, if I understood the information found correctly, the BAXI Duotec Compact + boiler is a 2-function, not 1-function boiler.
    For this reason, the 2-function boiler does not match the hot water tank with coil, but the layered tank. The coil is used with a single function boiler.
    Such remote advice does not make sense, because there are more questions and doubts than meaningful answers.
    If a service technician works for you, he knows better what you have there than we do on the forum.
    But with a 1-function boiler + a tank with a coil, the problem is the same, because at a given moment the water can be directed to the coil in the tank or to the radiators, and not to both at once, so again we return to the starting point, i.e. to the three-way valve.
    Unless you have some cosmic conversion of a 2-function boiler into a 1-function boiler and it can only be embraced by what it did.
  • #14 17076648
    Staszek8483
    Rate: 8
    What do I have the BAXI Duotec Compact boiler for? 2-function boiler,
    For hot water, I have a galmet heat pump with a 270 l coil, but this pump works economically up to 7 degrees outside, as it is cooler it does not pay. So the boiler is also used to heat the hot water which is in the container in winter. (that's what the service technicians advised me from the pump and boiler).
    As I have set on the boiler the heating itself which is all ok, hot radiators and not heating me hot water
    However, when I set it to heat the hot water it heats the water in the tank and the radiators get warm.
    I will add that as the boiler will set two functions at once, which is what and hot water it first heats the water in the tank and not the heaters.
  • #15 17076740
    BUCKS
    Help: 536
    Rate: 1086
    If you have a 2-function boiler, why do you need a domestic hot water heat pump
    For me, one excludes the other, because it does not generate any savings but unnecessary costs.
    If you have a 2-function boiler, it was enough to use it for domestic hot water, and if you need more hot water, it was enough to buy a 100-liter stratified tank after a shout.
    Or you could have bought a 1-function boiler + water heater coil tank.
    Having a gas boiler is buying a heat pump separately from a water heater, I consider it a waste of money.
    In addition, these circuses, because when the pump fails, you heat the domestic hot water with a 2-function gas boiler.
    I do not know about pumps, but for me someone swam and exaggerated in the solutions used. I wonder if you will ever pay back an investment in such a heat pump, or sooner this pump will go to scrap.
  • #16 17182262
    lesres
    A check valve must be installed on the heating circuit. I had a case with baxim that during hot water heating, he also mixed water in the floor circuit, but in the opposite direction, which is why the installation of the check valve helped.
    I don't remember exactly why it was happening, whether it was through the bypass or something else.
    I know it was a malfunction of this boiler, because it was a twin and in both houses there was the same problem with this boiler.
    No less a boiler worth recommending. Simple to build and cheap to operate.
    Returning to the topic of what boiler has the topic author installed. I am asking him to read the rating plate. Does it appear there:
    Duo-tec Compact + 20, 24 or 28
    whether
    Duo-tec Compact + 1.24
  • #17 17679457
    zyklonb82
    I have a question about the installation of a non-return valve in the return. I have a Baxi Duo tec boiler The floor has not been separated into a separate unit. It is on a common collector with radiators with thermostats used. The controller is set at 20 degrees inside there is a temperature of 21 to 22 degrees and I have a sense of what works. I have enabled water heating and CO.
    Will turning back (also from radiators) do the trick? BAXI Duotec Compact + Boiler: Unwanted Heating of Radiators & Nighttime Activation Issues20190106_1...733[1].jpg (1 MB)You must be logged in to download this attachment.
  • #18 17996893
    subratri
    Rate: 12
    It also looks like a return from the boiler to the radiators. Water will flow where it's easier. Or maybe some additional pump is installed and the system is not decoupled ...
    Diagrams for this furnace contain only solutions with solenoid valves to shut off individual circuits.
    I'm not a specialist, but I'm at the stage of choosing a furnace and installation. My attention was drawn to the fact that the circuits are cut off by a solenoid valve. At least with the c-MIX driver
✨ The discussion revolves around issues faced with the BAXI Duotec Compact + boiler, specifically unwanted heating of radiators when hot water is being heated and the boiler's nighttime activation. The user reports that despite multiple service visits and part replacements (including a stirrer and filter), the problems persist. Suggestions from other users include checking the room thermostat settings, changing the transmitter and receiver codes to avoid interference from neighboring units, and investigating the three-way valve, which is often implicated in such heating issues. The user also mentions having a heat pump and a 270-liter tank, leading to further discussions about the compatibility of the boiler with the hot water system. The conversation highlights the importance of proper diagnostics and the potential need for a more knowledgeable service technician.
TL;DR: On Baxi Duo‑tec Compact+ (20/24/28 or 1.24), “A check valve must be installed on the heating circuit” to stop radiators heating during DHW; reverse flow via a bypass can cause it. [Elektroda, lesres, post #17182262]
Why it matters: This FAQ helps Baxi Duo‑tec Compact+ owners and installers quickly diagnose cross‑heating and control issues to cut wasted energy and callouts.
Why do my radiators heat when I run hot water on a Baxi Duo‑tec Compact+?
A combi switches heat using a three‑way (diverter) valve. If it sticks or leaks, some heat flows to radiators during DHW. You may also notice reduced hot water capacity at higher tap flows. These signs point to a diverter valve issue. Ask service to check the valve and actuator. [Elektroda, BUCKS, post #17062268]
How do I stop the boiler turning on at night with a SALUS 091FLRF?
Factory DIP/jumper codes can match a neighbor’s transmitter and call your boiler. Change the address on both units.
  1. Power off the SALUS receiver and thermostat.
  2. Move the DIP/jumper address on transmitter and receiver to a unique code.
  3. Power up and test heat call; confirm only your thermostat controls the boiler. [Elektroda, dobroslaw, post #17060397]
Could my neighbor’s thermostat be firing my boiler?
Yes, if your wireless stat shares the same factory address. “We have all our guests in the block … before we put various codes.” Change the DIP/jumper code pair to a unique combination to stop cross‑talk. [Elektroda, slider2002, post #17060642]
What’s the quick fix if radiators warm while heating DHW?
Install a check (non‑return) valve on the heating circuit to block reverse circulation during DHW runs. This prevents migration into radiators or floor loops. Edge case: reverse flow can even warm floor circuits backwards via a bypass. The check valve cured this on twin installations. [Elektroda, lesres, post #17182262]
How can I confirm a stuck three‑way valve at home?
Turn central heating off. Open a hot tap to run DHW. Lightly feel radiator flow/return pipes near the boiler. If they warm, the diverter leaks, sending heat to CH during DHW. Book service to repair or replace the valve. [Elektroda, BUCKS, post #17062268]
Is my Baxi combi (2‑function) or single‑function, and why does it matter?
Check the rating plate. Duo‑tec Compact+ shows 20/24/28 for combis or 1.24 for a one‑circuit version. Knowing the exact model guides correct tank pairing and control strategy. It also steers the service toward the right hydraulic fixes. [Elektroda, lesres, post #17182262]
Can a 2‑function Baxi work with a coil storage tank?
A 2‑function (combi) pairs better with a stratified tank. Coil tanks are typically used with single‑function boilers. Mixing approaches can complicate control and hydraulics. If using a coil tank, ensure proper diverter and priorities. [Elektroda, BUCKS, post #17076563]
Does the boiler prioritize hot water over central heating?
Yes. With both functions enabled, it first heats the tank, then the radiators. Users observed DHW priority in real use. Plan schedules accordingly to avoid temporary CH dips during tank reheat. [Elektroda, Staszek8483, post #17076648]
My Legionella cycle heats too often—how should I set it?
If an automatic cycle runs more than intended, disable it and trigger manually when needed. One user had weekly set but saw daily heating and turned it off. Align Legionella runs with your heat‑pump schedule if used. [Elektroda, Staszek8483, post #17076344]
Is a PLN 700 “diagnostic fee” normal during warranty?
No. Warranty diagnostics should be covered. As one contributor put it, there is no such thing during warranty. Push for proper warranty handling from authorized service. Document symptoms and prior visits. [Elektroda, BUCKS, post #17076495]
Where should I put a non‑return valve to stop ghost heating?
Place a check valve on the heating circuit near the boiler to block back‑flow during DHW operation. This stops unintentional circulation into radiators or floor loops. A single correctly located valve often resolves the issue. [Elektroda, lesres, post #17182262]
My floor and radiators share one manifold—will a non‑return alone help?
It can help, but water follows the easiest path. Without hydraulic separation, cross‑flow may persist. Consider zone shut‑off (solenoid) valves or a mixing controller, like setups shown with c‑MIX. That isolates circuits during DHW and CH. [Elektroda, subratri, post #17996893]
After changing the SALUS code, the night firing stopped—anything else to do?
Monitor for a week to confirm stability. Ensure transmitter and receiver share the same new code. Keep the previous code documented to avoid duplicates in the building. The change has resolved spontaneous firing for others. [Elektroda, Staszek8483, post #17072271]
Why does my boiler show 30–35°C and warm radiators at night?
That reading suggests a low‑level heat call while the room stat shows standby. A misaddressed wireless thermostat can trigger this. The reported 30–35°C flow at night matched a control conflict case. Readdress the stat and receiver to unique codes. [Elektroda, Staszek8483, post #17058843]
Do I need factory Baxi service, and which controller type matters?
Use authorized Baxi service for these new units and confirm controller type. State if it’s on/off, TPI, or Baxi communication, and whether an outdoor sensor is fitted. Share where the controller is wired. It speeds accurate diagnosis. [Elektroda, dobroslaw, post #17058592]
