[Solved] GRAPHITE 58G528 Rotary Hammer Review: 900W, Construction Sites & Electrical Installations
waldek099 6726 3
  • #1 17065001
    waldek099
    I am looking to buy this Graphite 900W rotary hammer, it will be used mainly on construction sites to drill holes for electrical boxes, mainly electrical installations, etc. one two construction sites a month, someone uses it? Can he make some sense about this equipment or recommend something at a similar price and with good parameters, and who will not fall apart when drilling the first hole? greetings
  • #2 17065020
    lukaszd82
    Help: 143
    Rate: 491
    This is equipment for amateur use and will not last long with regular use. Better to buy something better right away.
    What will you do? For regular drilling holes for cans, I recommend a more powerful machine, because any other machine will quickly give up the spirit.
    And here is info from another forum:
    1. The diamond bit cuts the concrete - it is designed to work without impact - the diamond wears off when drilling.
    2. Vidia crown knocks a hole like a drill - the rotating movement is used to discharge the spoil.
    Due to the large diameters = large contact area between the drill bit and the wall, a high impact force is required to penetrate the drill bit into the hard material. I would suggest to consider buying a SDS MAX hammer drill with an impact force of 7J, I would like to emphasize not the company's one, for about 400 - 450 PLN. and lace.
    I adhere to the principle that it is better to buy better equipment once, and with proper care and maintenance, you will have peace of mind for years. Some people buy cheap and just exchange.
    However, for such works it is rather SDS MAX and not PLUS ...
  • #3 17074036
    waldek099
    thanks for the hint I think helpful
  • #4 17074038
    waldek099
    Added after 35 [seconds]:
    I bought by advice
