Cannot Install Windows 10 on 2-Month-Old SSD: Format Issues, Error Messages, & Bad Sectors Found
karwolo 3678 8
  • Suspected SSD failure causing format and install errors
    #1 17049927
    karwolo
    Hello, the win system 10 started to behave strangely, the explorator did not work sometimes the start button, so I wanted to put the system up again. The new laptop is 2 months old. Unfortunately, the attempt to format the disk while installing Windows was unsuccessful. Apparently it appears with success, but nothing happens, the disks can not be removed either. I tried in konosli clean and clena all (- here it crashed an error that I do not have permission somehow) to write with zeros, also nothing. When I exit the installation, the old browser normally boots up. I tried to format the same on linux - nothing. I will add that I also checked the disk for bad sectors and at the beginning of the disk it found around 60. The disk has some strange name (when I check in the system) as if it lost it in some way. Anyone know how I can fix it? I've been sitting on it the other day looking for some programs to do this, but none has worked so far.
  • Replace the SSD and provide SMART data
    #2 17049934
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Welcome. With this amount of information - replace the drive with a good one.
    And if you want to write - enter the disk model and insert its SMART, enter the laptop model or if it is a desktop computer, at least a motherboard model - you can debate what to do with it. With this amount of information, any discussion of your problem doesn't really make much sense.
    We only know that you want to install Windows 10, it is not known on which computer, it is also known that you have a damaged disk, but it is not known what - it is not known what the degree of damage is. So what do you expect? :)
  • SATAFIRM S11 SSD and MBR conversion issue
    #3 17049939
    karwolo
    Thanks a lot for your interest! The laptop is a Lenovo 310-15isk, I have no idea what the disk motel has because now I will not find it because it displays as the name SATAFIRM S11. Tell me how to find this SMART?
    Currently trying to reset the entire disk with Ubuntu because apparently it is one of the ways to fix bad logical sectors. I do this with sudo dd if = / dev / zero of = / dev / sda bs = 8M
    Generally, at the beginning it was a problem that the installer saw the disk as GPT, so I converted it to MBR. Maybe it damaged it, I don't know, but when I try to install on the largest win10 partition, something said that there may be problems because something is wrong with the file system or something similar. When I'm done with linux I will write it exactly.
  • Suggesting SMART and hdparm checks for SSD diagnosis
    #4 17049941
    dt1
    Help: 7315
    Rate: 8292
    Under ubuntu SMART you will display the command:
    sudo smartctl -a / dev / sda
    If it doesn't find this command, you'll need to install smartmontools (sudo apt-get install smartmontools).
    You can get information about the disk by entering the command: sudo hdparm -iI / dev / sda (the minus is two letters I like Irena - small and large).
    Ultimately, the drive model can be read from its label. You have a disk from new? How much has he lived?
  • SATAFIRM S11 SSD identified as suspicious firmware state
    #5 17049946
    karwolo
    INFFORAMCJE O DYSKU, nad SMARTem jeszcze pracuje bo albo chodzi o live cd albo cos nie tak z repozytorium Ubuntu do tego.
    ubuntu@ubuntu:~$ sudo hdparm -iI /dev/sda
    /dev/sda:
    Model=SATAFIRM S11, FwRev=SBFM71W1, SerialNo=B5BE077414CF00116074
    Config={ Fixed }
    RawCHS=16383/16/63, TrkSize=0, SectSize=0, ECCbytes=0
    BuffType=unknown, BuffSize=unknown, MaxMultSect=16, MultSect=16
    CurCHS=16383/16/63, CurSects=16514064, LBA=yes, LBAsects=468862128
    IORDY=on/off, tPIO={min:120,w/IORDY:120}, tDMA={min:120,rec:120}
    PIO modes: pio0 pio3 pio4
    DMA modes: mdma0 mdma1 mdma2
    UDMA modes: udma0 udma1 udma2 udma3 udma4 udma5 *udma6
    AdvancedPM=no WriteCache=enabled
    Drive conforms to: Unspecified: ATA/ATAPI-3,4,5,6,7
    * signifies the current active mode
    ATA device, with non-removable media
    Model Number: SATAFIRM S11
    Serial Number: B5BE077414CF00116074
    Firmware Revision: SBFM71W1
    Transport: Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6, SATA Rev 3.0
    Standards:
    Supported: 11 10 9 8 7 6 5
    Likely used: 11
    Configuration:
    Logical max current
    cylinders 16383 16383
    heads 16 16
    sectors/track 63 63
    CHS current addressable sectors: 16514064
    LBA user addressable sectors: 268435455
    LBA48 user addressable sectors: 468862128
    Logical Sector size: 512 bytes
    Physical Sector size: 512 bytes
    Logical Sector-0 offset: 0 bytes
    device size with M = 1024*1024: 228936 MBytes
    device size with M = 1000*1000: 240057 MBytes (240 GB)
    cache/buffer size = unknown
    Form Factor: 2.5 inch
    Nominal Media Rotation Rate: Solid State Device
    Capabilities:
    LBA, IORDY(can be disabled)
    Queue depth: 32
    Standby timer values: spec'd by Standard, no device specific minimum
    R/W multiple sector transfer: Max = 16 Current = 16
    DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6
    Cycle time: min=120ns recommended=120ns
    PIO: pio0 pio1 pio2 pio3 pio4
    Cycle time: no flow control=120ns IORDY flow control=120ns
    Commands/features:
    Enabled Supported:
    * SMART feature set
    Security Mode feature set
    * Power Management feature set
    * Write cache
    * Look-ahead
    * Host Protected Area feature set
    * WRITE_BUFFER command
    * READ_BUFFER command
    * NOP cmd
    * DOWNLOAD_MICROCODE
    SET_MAX security extension
    * 48-bit Address feature set
    * Device Configuration Overlay feature set
    * Mandatory FLUSH_CACHE
    * FLUSH_CACHE_EXT
    * SMART error logging
    * SMART self-test
    * General Purpose Logging feature set
    * WRITE_{DMA|MULTIPLE}_FUA_EXT
    * 64-bit World wide name
    * WRITE_UNCORRECTABLE_EXT command
    * {READ,WRITE}_DMA_EXT_GPL commands
    * Segmented DOWNLOAD_MICROCODE
    * Gen1 signaling speed (1.5Gb/s)
    * Gen2 signaling speed (3.0Gb/s)
    * Gen3 signaling speed (6.0Gb/s)
    * Native Command Queueing (NCQ)
    * Phy event counters
    * READ_LOG_DMA_EXT equivalent to READ_LOG_EXT
    * DMA Setup Auto-Activate optimization
    Device-initiated interface power management
    * Software settings preservation
    * DOWNLOAD MICROCODE DMA command
    * SET MAX SETPASSWORD/UNLOCK DMA commands
    * WRITE BUFFER DMA command
    * READ BUFFER DMA command
    * DEVICE CONFIGURATION SET/IDENTIFY DMA commands
    * Data Set Management TRIM supported (limit 8 blocks)
    Security:
    Master password revision code = 65534
    supported
    not enabled
    not locked
    frozen
    not expired: security count
    supported: enhanced erase
    20min for SECURITY ERASE UNIT. 60min for ENHANCED SECURITY ERASE UNIT.
    Logical Unit WWN Device Identifier: 5000000000000000
    NAA : 5
    IEEE OUI : 000000
    Unique ID : 000000000
    Checksum: correct
    ubuntu@ubuntu:~$
    A Jeszcze gdy probuje tutaj (Ubuntu) zamontowac dysk to wylatuje mi to:
    Error mounting /dev/sda2 at /media/ubuntu/C078991A78991070: Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=999,gid=999" "/dev/sda2" "/media/ubuntu/C078991A78991070"' exited with non-zero exit status 14: The disk contains an unclean file system (0, 0).
    Metadata kept in Windows cache, refused to mount.
    Failed to sync device /dev/sda2: Input/output error
    Failed to mount '/dev/sda2': Operation not permitted
    The NTFS partition is in an unsafe state. Please resume and shutdown
    Windows fully (no hibernation or fast restarting), or mount the volume
    read-only with the 'ro' mount option.
  • #6 17049949
    dt1
    Help: 7315
    Rate: 8292
    Identifying the model as SATAFIRM S11 looks like corrupting the firmware of this drive, but wait for a second opinion. This is the drive with the Phison PS3111-S11 controller.
    If so, is the drive under warranty?
  • #7 17049973
    Kasek21
    Help: 4981
    Rate: 3547
    Damaged disk - if there is "dialect", give it back.
  • Questioning whether Lenovo warranty covers the SSD issue
    #8 17050495
    karwolo
    In general, the entire lenovo laptop is under warranty, it probably also applies. Although it's Lenovo, you never know. Has anyone ever returned a laptop like this? And one more thing, that this old windows really boots without any problems and it is possible to work on it. It's not like that old widnows somehow magically secured the disk against modification? Because on it I can delete files and on other systems the disk is read-only.
  • #9 17050539
    Kasek21
    Help: 4981
    Rate: 3547
    Yes, as long as they do not diagnose a mechanical fault.
A user is experiencing issues installing Windows 10 on a 2-month-old SSD, identified as SATAFIRM S11, in a Lenovo 310-15ISK laptop. The installation fails during disk formatting, and attempts to clean the disk using both Windows and Linux result in errors, including bad sectors detected on the drive. The user has tried various methods, including converting the disk from GPT to MBR and using the `dd` command in Ubuntu to reset the disk. Responses suggest that the drive may have firmware corruption and recommend checking the SMART status for further diagnostics. The user is considering warranty options for the laptop and is uncertain if the existing Windows installation is preventing modifications to the disk.
