[Solved] Low Oil Pressure Issue: Mini Cooper 1.6 120 HP (2006) - Warm Engine Pressure & Repair Advice
najciekawsza 20235 3
  • #1 17091273
    najciekawsza
    Hello, I have a Mini Cooper 1.6 120 horsepower, 2006. the low oil pressure light comes on. We have 4 bars on a cold engine, 0.5 bars on a warm engine. The dragon, oil pan, oil change and installation of the original filter were not cleaned. What should be the correct idle pressure when the engine is warm? I am asking for professional advice. I have a choice to sell a car or repair the engine ..
  • #2 17092253
    KMal
    Help: 340
    Rate: 1434
    Maybe you don't need to panic.
    See what the instructions for this engine say. Only a quarter bar at low speed.
    Check the sensor at what pressure the lamp turns on.
  • #3 17093043
    najciekawsza
    The sensor lights up at 0.4
    After 5 months the oil filter was very screwed on. Now I have the original one and the pressure only increased by 0.2.
  • #4 17116279
    najciekawsza
    Hello problem solved by 3rd mechanic.
    The problem was a scratched oil pump. After replacement, the pressure increased to 2.5 bar.
    I write because maybe someone will need such information.
