Choosing Quality SDS Plus Drill Bits for DIY Projects: Drilling in Block and Wood
WSRH 5898 9
How should I choose good SDS Plus drill bits for drilling mostly in block/concrete and occasionally in wood, and are drill bit sets worth buying?
For wood, use regular drill bits in a normal chuck; with only an SDS Plus drill, use an SDS Plus-to-1/2" adapter and drill without impact, because wood drilling with SDS is inconvenient [#17094022][#17094289][#17094325] For the wall/block, buy SDS Plus masonry bits, and for DIY use a Makita or Bosch set can be acceptable, though the cheaper sets are basically Chinese-made and their quality matches the price [#17094309][#17094622] If you want better quality for more demanding amateur use, it is better to buy better bits individually, such as Hitachi star-shaped carbide bits, instead of relying only on the basic set [#17094622] Even inexpensive sets around PLN 50 can work, but solid concrete needs a drill with enough power, not the cheapest model [#17094735]
  • #1 17094006
    WSRH
    Rate: 62
    Hello, gentlemen, I bought a drill with SDS Plus system, I need some drill bits for this. Isn't it worth buying sets, as is the case with regular drill bits? Is there anything of good quality in any kit?
    I will drill mainly in the wall of a block and sometimes in wood, and I need these two. Definitely for a DIY enthusiast than professionally and profitably.
  • #2 17094022
    stanislaw1954
    Help: 2013
    Rate: 4668
    WSRH wrote:
    I will mainly drill into the wall of the block
    What are your walls? Solid concrete or brick?
    WSRH wrote:
    sometimes in wood
    For wood, these drill bits are similar to those for metal and are mounted in a "traditional" handle.
  • #3 17094259
    WSRH
    Rate: 62
    WSRH wrote:
    sometimes in wood
    Concrete, like in a traditional holder? As i only have sds plus.
  • #5 17094304
    WSRH
    Rate: 62
    Well, I didn't know about it ...
    What about these drill bits and kit?
  • #6 17094309
    paszczakq
    Help: 48
    Rate: 204
    MODECO drills from the market to play at home will be ok. Optionally some BOSCH.
  • #7 17094325
    mychaj
    Help: 214
    Rate: 941
    How big is this drill? In wood, SDS with an attachment is a lot of trouble - unless you have big biceps ... :-)
    I would rather buy a regular drill.
  • #8 17094587
    WSRH
    Rate: 62
    I will be using it 95% concrete 5% wood.
  • #9 17094622
    Michelson
    Help: 82
    Rate: 305
    For amateur use, I once bought a set of Makita drills and chisels and there is no madness - typical Chinese food, the price is about PLN 100 per set, the quality is adequate to the price. For more demanding applications, although still amateur I buy Hitachi star-shaped carbide drill bits, they are of much better quality than in this set. In my opinion, it is better to buy better drill bits according to your needs.
  • #10 17094735
    stanislaw1954
    Help: 2013
    Rate: 4668
    These amateur sets of drills, about PLN 50 on portals, also drill, but in solid concrete there must be more power of the drill, not the cheapest of the newspapers.
The discussion revolves around selecting quality SDS Plus drill bits for DIY projects, specifically for drilling in concrete blocks and wood. Users emphasize the importance of using appropriate drill bits for different materials, noting that wood drilling typically requires a non-impact approach with a standard drill. Recommendations include MODECO and BOSCH drill bits for general use, while for more demanding tasks, users suggest investing in higher-quality options like Makita and Hitachi carbide drill bits. The consensus is that while cheaper sets are available, they may not perform well in solid concrete, and it is advisable to choose drill bits based on specific needs rather than purchasing generic sets.
