[Solved] Corrupt Win7 Registry Keys: Avast Pro Antivirus, Damaged Elements, Disable Programs, Java Update
13698 6
  • #1 17095527
  • #2 17095793
    Pedros050
    Help: 2471
    Rate: 3926
    Hello. Avasta can be removed immediately before he can not do any major problems. For example, a computer will be infected and then the forum should be changed. And damaged elements of the registry need to be repaired or removed if there are remains of deleted programs. I suggest installing a registry cleaning program, eg CCleaner. https://www.ccleaner.com/
  • #3 17096038
    Pedros050
    Help: 2471
    Rate: 3926
    If CCleaner has removed unnecessary registry entries then you do not have to remove only this application, uninstall Digital TV Tuner and delete the key from the registry later. What's in the Lavasot folder? Antivirus which to win 7 is only https://support.microsoft.com/en-us/help/14210/security-essentials-download
  • #5 17097939
  • #6 17098053
    Pedros050
    Help: 2471
    Rate: 3926
    "How to disable network access to the Windows registry to prevent the possibility of viewing the registry? Do you need it, or this is also due to the advertising of Avastu" Avastu advertising. Uninstall and remove the key from the registry. All programs that you have removed need to remove keys from the registry because you're making a garbage in your computer. You are checking here. HKEY_CURRENT_USER-HKEY_CURRENT_USER \ Software and remove the key of the deleted program from there and the same in HKEY_LOCAL_MACHINE-Software. And what about your disc to check on the manufacturer's website GIGABYTE GA-Z77-D3H Rev: 1.0 is there a newer BIOS? If you do not have it, you do not need to upgrade.
  • #7 17625200
The discussion revolves around issues with corrupted Windows 7 registry keys, as identified by Avast Pro Antivirus, which reported numerous damaged elements and programs that slow down system performance. Users sought advice on how to disable or remove problematic software, including Windows Media Center and Java 8 Update 151, while expressing skepticism about Avast's motives in promoting its products. Recommendations included using CCleaner for registry cleaning and uninstalling unnecessary applications. The conversation concluded with the original poster deciding to uninstall Avast due to dissatisfaction with its support and persistent upselling tactics.
