Smoke Stick V8 - Best Switch for 20A Output Power to Prevent Explosion While Vaping
fazinho 4437 7
  • #1 17096059
    fazinho
    Rate: 25
    Hello, I would like to ask what switch I can solder here, because I do not want my friend to explode the pipe when vaping. Thank you for your help.
    Edit: I will add that the output power is 20 A.
  • #2 17096162
    goldi74
    Help: 1367
    Rate: 1539
    A simple little switch is enough. In this Dragon there is electronics that switch high current through a MOSFET transistor key.
  • #3 17096247
    fazinho
    Rate: 25
    So nothing will explode, nothing to worry about? 4-pin switch is indifferent and is it to rock? I searched for a schematic for it, but found nothing, and I don't have time to sit for a few hours to find the schematic. But if someone had and would be willing to send, it will definitely be useful for the future.
  • #4 17096325
    goldi74
    Help: 1367
    Rate: 1539
    Little chance of finding a schematic. The original has a regular switch mounted just like in other structures of this type. The only requirement is to find one that will fit mechanically, because there is often little space to install a switch that is too large.
  • #5 17096353
    Krzysztof Kamienski
    Help: 2033
    Rate: 5165
    @ goldi74 The colleague forgot about the current regulation, or rather its stabilization by the PWM system (on MOSFET)? You will be "blessed" by Vaporowicz :D for the daily replacement of heaters. :cry:
  • #6 17096365
    fazinho
    Rate: 25
    If someone read this and had such a diagram, or in general diagrams for any other electricians, I would ask, because I have some dead bodies. I do not worry about the switch, because it seems to me that it is similar to the switch from se k300i, if it fits, I will let you know. Regards and thanks for the answer.
    Added after 17 [minutes]:
    Can you expand a little?
  • #7 17096480
    goldi74
    Help: 1367
    Rate: 1539
    There is no PWM to regulate the power in the Stick V8, so there is nothing to forget about. And even if it was PWM, what does it have to do with the switch replacement?
  • #8 17097136
    Freddy
    Help: 1394
    Rate: 2820
    Power in A, I think someone made a mistake.
The discussion revolves around selecting a suitable switch for the Smoke Stick V8 to handle a 20A output power safely, preventing potential explosions while vaping. Participants suggest that a simple switch is adequate, as the device utilizes a MOSFET transistor for high current switching. Concerns about finding a schematic for the switch are raised, with advice to focus on mechanical compatibility due to space constraints. Clarifications are made regarding the absence of PWM power regulation in the Stick V8, emphasizing that the switch replacement is straightforward. The conversation also touches on the importance of current stabilization and the need for proper component selection.
