How to recover my windows data from corrupted and inaccessible state ?
Abrienne 2142 6
  • #1 17104506
    Abrienne
    Please give me some suggestions on how to recover my corrupted Windows data files. It's urgent !!!!
  • #2 17155296
    gabik001
    Level 37  
    Help: 305
    Rate: 418
    Is hard drive readable or visible in other computer when connected?
    You might do sector by sector copy of the hdd using DMDE software.
  • #3 17157813
    Selvi2
    Hi
    I have used Sysinfo tools Window Data Recovery Software when my important documents got inaccessible. Believe me, I found it to be the best from the rest of the available tools. I hope this will help you too to extract your files back to the original state.
    Thanks
    Selvi
  • #4 17159753
    Tirthankar
    What type of error you are facing?
  • #5 17176673
    Abrienne
    An error like "your file is corrupted or inaccessible"
  • #7 17241744
    uda1
    what is the exact error message, was the file readable before and what even happened that it is not readable anymore?
    you can first use CrystalDiskInfo to see what state the disk is in and then it would be better to clone the whole disk anyway with ddrescue.
    whatever you do, do not at least use the "chkdsk" command in command prompt because that might actually delete all of the corrupt files...(if sectors are "unreadable")
The discussion revolves around recovering corrupted and inaccessible Windows data files. Users suggest various methods, including checking if the hard drive is readable on another computer and using DMDE software for sector-by-sector copying. One user recommends Sysinfo Tools Windows Data Recovery Software as an effective solution for retrieving important documents. Additional advice includes consulting a Microsoft thread on directory corruption and using CrystalDiskInfo to assess disk health. Caution is advised against using the "chkdsk" command, as it may delete corrupt files if sectors are unreadable.
