Eco-Pea Coal Stove Problem: Feeder Self-Extinguishing, Temp Not Exceeding 35°C, Smoke Issue
Pati9191 15420 2
  • #1 17116338
    Pati9191
    Hello. I have a stove with a feeder for eco-pea coal. Generally, no matter how often the frequency of feeding eco-pea coal is set, the temperature on the stove has not exceeded 35 degrees for two weeks, and it has always been around 55 degrees. The dimming turns on by itself from Saturday. The ignition comes for 3 hours and then it goes out again and again and again. I've already done a reset, it helped for a day. Today, the extinguishing has turned on again, and when I wanted to sprinkle eco-pea coal, the smoke went into the feeder with this container for eco-pea coal.
    • Eco-Pea Coal Stove Problem: Feeder Self-Extinguishing, Temp Not Exceeding 35°C, Smoke Issue received_1261247094019386.jpeg (646.27 KB) You must be logged in to download this attachment.
  • #2 17116370
    Loker
    Help: 575
    Rate: 721
    If smoke flows back into the feeder, check / clean the chimney.
  • #3 17116723
