GSM Signal Amplifier - Recommended Home Models, 300 PLN Range, LTE Compatibility
varikap92 27624 6
  • #1 17119025
    varikap92
    What amplifiers you recommend for home use. Will those with alledroge about 300 PLN give advice? Do such amplifiers also strengthen the LTE signal
  • #3 17119052
    sq9fmc
    Help: 129
    Rate: 406
    Do not install the GSM amplifier yourself because it is a transceiver device for which permission is required.
    https://bip.uke.gov.pl/ostrzezeniawyroby-niezgodne/szkodliwe-wzmacniacze-gsm,1.html
    UKE inspectors find such equipment easily and this threatens legal consequences. Contact the telephone network operator; they install it on their own in justified cases.
  • #4 17119118
    nutergsm
    Help: 1034
    Rate: 1663
    Look at the forum there were several such topics.
  • #5 17119881
    seba694637
    Help: 11
    Rate: 114
    Only those with more power. Provided for the area of 200m?, they break through only one thin wall of the so-called max blocks. LTE can also be strengthened, but LTE or internet will work well only at the amplifier itself. A few steps away will drop upload and grow pings. If you have wifi in a flat, it is better to buy a good 2g 800mhz amplifier per band. For this antenna, eg ATK20 and a good internal antenna for given bandwidth. Ew divide the signal into two antennas inside.
    The external antenna must be as far away as the internal antenna. That it would not loop the signal
  • #6 17705205
    RolandV
    Rate: 64
    I will ask you too,
    I have an antenna for internet for LTE and it's ok,
    I have a problem with GSM coverage for phone calls, what amplifier is best to buy not to interrupt LTE.
    and antennas from the GSM repeater must be far from the LTE antenna, does not it matter?
  • #7 18899487
    Tomaszek 55
    Rate: 31
    I reheat the topic, because after changing the operator to Plus, being on a plot by the lake became a punishment, not a relaxation. The GSM signal "floats" on the verge of non-existence. One should rather forget about the Internet. Of course, I know the objections to criminal records, but no one lives within a kilometer (in terms of habitat). For me, one Plus will not put up a repeater. In addition, the device would only work on weekends, while on the plot. Therefore, I am asking for substantive advice on what device to choose.
✨ The discussion revolves around recommendations for GSM signal amplifiers suitable for home use within a budget of approximately 300 PLN, with a focus on LTE compatibility. Users express concerns about legal implications of self-installation, emphasizing the need for professional installation due to regulatory requirements. It is noted that amplifiers with higher power ratings are necessary for effective coverage, particularly in larger areas or when multiple walls obstruct signals. Users also highlight the importance of separating GSM and LTE antennas to avoid interference. Specific suggestions include using a 2G 800MHz amplifier and appropriate antennas like the ATK20 for optimal performance.
