Improve Mobile Internet Signal at Jerzykowice Wielkie 26: Modem & Router Recommendations
marekdudekmarek 15588 12
How can I improve the mobile internet signal at Jerzykowice Wielkie 26, and what modem/router should I buy?
The best fix is to stop relying on Plus if you can, because in this location its LTE1800 BTS is described as overloaded and weak, while Orange, T-Mobile or Play have better coverage there [#16420529] [#16441325] If you must stay with Plus, the suggested setup is an LTE router such as the Huawei B315 plus a dual LTE antenna for 1800 MHz from Cybertech with about 15 dBi gain [#16443640] [#16446939] Even with an antenna, do not expect miracles, because the limiting factor is the overloaded BTS, not just the indoor signal level [#16441325] [#16446939] Before buying, test the different networks at home and near the BTS and check signal parameters, ideally with Network Cell Info or similar data from the GAUGE/RAW screens [#16420529] The thread also warns against GSM repeater/amplifier solutions, which are illegal for private users in Poland [#16443660] [#16443900]
  • Seeking modem and router recommendations for weak 3G signal
    #1 16420153
    marekdudekmarek
    Hello!
    The subject probably rolled but for Tel I'm getting lost here and I'm new to it. I have a great request if someone could advise me how best to strengthen the mobile internet signal in a positive way. In the home range on the computer is not at all and on Tel lapie sometimes 3G but it disappears. At home I once caught up with a laptop and I was able to catch a few meters from the house, but only 1 dash of range. What type of modem call and router should I buy? My location is Jerzykowice Wielkie 26. Kolo Kudowa Zdrój. I am asking you for help. greetings
    Switching from Plus and measuring LTE signal parameters first
    #2 16420529
    matek451
    Help: 4352
    Rate: 5808
    The optimal decision is to give up on Plus. This is not the operator for this location. One BTS LTE1800aero2 with doubtful reach in addition, probably overloaded it is not the peak of dreams. What is the offer from Plus, and what are the speeds on this LTE ribbon? Install Network Cell Info on your phone, find the LTE range (this line) and show the NCI screen with signal parameters and BTS data (GAUGE tab, RAW tab).
  • #3 16424520
    marekdudekmarek
    There is no other internet in this village. Plus is the only option. I read a little about it and people write that the antenna should give something. I mean just what kind of antenna modem and router to buy that suited it to sienbie and my location is afraid I do not know how it works and I do not know the equipment. I heartily ask for a hint :)
  • Recommends home and BTS tests before choosing an operator
    #4 16424556
    matek451
    Help: 4352
    Rate: 5808
    What people write on the Internet about mobile internet does not matter to me, 90% is nonsense. I asked specific test questions and the answers to them are the basis. of course it is not true that only Plus is the only operator with coverage in your town. Where does this claim come from? Other Orange or Play operators have a much better coverage. I will repeat it again, plus this is not the operator for this location. The purchase of the antenna may allow you to use the LTE1800aero2 BTS but for now we do not know how it works. In such locations, they are overloaded and LTE Plus operates massacre. Hence, tests at home and under BTS are recommended. Plus, for several years, he did not modernize the network and today is the worst mobile operator. What is this offer in Plus, subscription without equipment?
  • #5 16441175
    marekdudekmarek
    Plus, I've got it from my father for free, it's a portable internet, I bought the starters of all networks and tested it at home and nothing, just plus something to catch, next to the neighbor has a plus and also says that it is a plus. I made a screen only through another program because there was no Network Cell Info in the store, maybe because I have a windows. One jet measurement from under the relay and the other from the balcony. The wheel of the house did not want to catch LTE, I would have to leave with 100m, there is one line of LTE sometimes. These pictures are suitable? Is it known what equipment to choose? Thank you for your help. Greetings .
    • Improve Mobile Internet Signal at Jerzykowice Wielkie 26: Modem & Router Recommendations Speedtest result on_2017-04-27 07_39_35.jpg (143.19 KB) You must be logged in to download this attachment.
    • Improve Mobile Internet Signal at Jerzykowice Wielkie 26: Modem & Router Recommendations Speedtest result on_2017-04-26 20_53_48.jpg (147.63 KB) You must be logged in to download this attachment.
  • #6 16441325
    matek451
    Help: 4352
    Rate: 5808
    Listen to your neighbor, he is a professional as he looks and knowledge probably draws from Plus's ads on TV Polsat. Why are screens with speeds? The only advantage is the latter, probably from the BTS showing how massacre it is overloaded. The first on the balcony probably 3G with UMTS900aero2. But in Plus on 3G there are strict limits. It's 3g you have DL like LTE under BTS. What did your tests like Orange, T-Mobile or Play look like? Orange and T-Mobile have LTE1800Networks on G.Parkowa, and LTE800 for both operators in Lewin Kłodzki-Jarków. Play has BTSs LTE1800, LTE2100 and on G. Parkowa and LTE1800, LTE2100 and LTE800 on BTS Buczka 16 in Kłodzko. Investing in LTE from Plus, which under BTS provides up to 3Mb / s is a failure.
  • #7 16443011
    marekdudekmarek
    I bought the starters of all networks and tried to catch the range on the laptop, only with a plus catch on the balcony. I thought that this program was something you wrote to get it. It may give some equivalent because I can not download my phone. these screenshots are one of the balcony, and the other from the relay from the top of the park.
  • #8 16443632
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    wawxx wrote:
    GSM reapetera.
    Are they legal in Poland? Only somehow, no one mentioned the external Yagi-type antenna aimed at BTS. Well, how is this ... additional device ... laptop cable ...
  • #9 16443640
    matek451
    Help: 4352
    Rate: 5808
    Of course they are illegal and a friend's post on this subject is a nonsense. Tests made under the BTS-LTE1800 Aero2 from G. Parkowa showed massive overloading. With a correct LTE DL signal up to 4Mb / s UL up to 18Mb / s. The antenna will not change this, but if a colleague has 200 zlotys to spend, let them buy a dual LTE at 1800MHz from Cybertech and convince himself.
  • Signal boosters require operator installation under Polish regulations
    #10 16443660
    wawxx
    Help: 16
    Rate: 9
    The provisions of the Ordinance of the Minister of Administration and Digitization of 12 December 2014 (consolidated text Dz.U.2017 item 96) on radio transmitting or transmitting and receiving equipment that can be used without a radio license show that only telecommunications undertakings with nationwide frequency reservations may use GSM signal amplifiers.
    If an individual user (an individual or a company) would like to strengthen the signal of the mobile network in the place where the telephone is used, he should ask the operator of his network to install such a device. The correct operation of signal amplifiers depends not only on their technical parameters, but also on the place and method of their installation, used antenna and configuration with operating base stations of mobile telephony.
  • GSM repeater installation is illegal in Poland
    #11 16443900
    matek451
    Help: 4352
    Rate: 5808
    Well, look back and see what they will answer. At one time, Orange offered such a service with its equipment, for a fee. The other operators are not playing at it. There are a lot of GSM repeaters on the market from China, their self-assembly is illegal and punished. all you need to do is read http://www.telepolis.pl/wiadomosci/uke-przypo...acniacze-sygnalu-sa-nielegalne,2,3,38475.html In your post you offered to buy a GSM repeater yourself and mount it, ie a solution forbidden by applicable law in Poland.
  • #12 16446862
    marekdudekmarek
    So, just dual lte like that? What about the modem and the special router?
  • #13 16446939
    matek451
    Help: 4352
    Rate: 5808
    And what is the offer from Plus? The subscription is best with the equipment. If you want to buy yourself, it's an LTE router, e.g. B315. dual LTE antenna at 1800 MHz from Cybertech with 15 dBi gain. Lack of LTE1800 signal tests in your location does not allow you to determine if the signal parameters will be satisfactory. Do not expect much, the BTS speed test showed a huge overload BTS-LTE1800Aero2, low DL compared to UL, which is 4-5 times greater. plus it has poor infrastructure, insufficient to serve all customers using its LTE in this area. The lack of development plans for the Plus network in Kudowa may be even worse.
The discussion revolves around improving mobile internet signal at Jerzykowice Wielkie 26, where the user experiences poor connectivity with Plus, the only available operator in the area. Recommendations include considering alternative operators like Orange or Play, which reportedly have better coverage. Users suggest investing in a dual LTE antenna, specifically at 1800 MHz, such as the Cybertech model with 15 dBi gain, and an LTE router like the B315. Concerns about the legality of signal amplifiers and repeaters in Poland are raised, emphasizing that only licensed telecommunications companies can use such devices. The overall sentiment indicates that Plus may not be the best choice due to network overload and insufficient infrastructure.
