Is Schuko Socket Worth Adopting in Poland? Benefits & Compatibility with Uni-Schuko & Europlugs
BANANvanDYK 30807 17
  • #1 17125022
    BANANvanDYK
    Help: 1167
    Rate: 2602
    Do not you think that Schuko sockets should be used more and more often in Poland? Most European and Euro-Asian countries use Schuko sockets and plugs:
    https://en.wikipedia.org/wiki/Schuko#History
    The devices equipped with uni-schuko plugs (CEE 7/7) or Europlug (CEE 7/16, CEE 7/17) have been the standard in Poland for many years. Recently, I even bought a cable plug in the shop in the uni-schuko standard, in a form that was used even during PRL, so there should be no problem with migration.
    The advantages of Schuko:
    - there are no problems with reversing the plug. There is no problem with that, for example, the power supply on the extension cable will not fit. A smaller problem with the fact that, for example, time trials can not be put in the so-called hermetic, because the can must be at the top so you have to break the flap. In addition, they take a second slot in double sockets. The real solution - you need to buy a lot more expensive equipment with a housing at the bottom.
    Disadvantages:
    - old plugs and devices that remember the times of PRL, originating from the USSR (and so they do not fit into the sockets with a protective pin) and those typically Polish and the French standard do not match.
    I would put such sockets next to the usual nests of the French standard in my home and workshop, so that there is always a choice. Nobody is forbidden to do this in my home. Only what would you think about it? Do you use such sockets, have you already convinced them?
  • #2 17129480
    RafZielak
    Rate: 24
    Everything would be beautiful if all the installations worked in TN-S or in TN-CS. In PL we still have too many sculptures around the houses, even more in all sorts of extensions and devices, ubiquitous zeroing and this protective pin, however, nicely positioned plug in the slot "guaranteeing" that the phase wire will be on the left (when "pin" on top ).
    RafTec
    Prezydenta Ryszarda Kaczorowskiego 12, Sochaczew, 96-500
  • #3 17129487
    kkas12
    Help: 1076
    Rate: 4313
    RafZielak wrote:
    ... and this protective pin, however, nicely positions the plug in the socket "guaranteeing" that the phase wire will be on the left side (when "pin" on top).
    Buddy, it's time to finish these fairy tales by "positioning" the plugs in the sockets.
    And besides, the nest in question will not pass the exam in an installation where protection against electric shock is zeroing or earthing?
    But why?
  • #4 17129499
    mawerix123
    Help: 482
    Rate: 951
    And what are the contraindications for TT installations :?:
    RafZielak wrote:
    however, it nicely positions the plug in the "guarantee" slot that the phase wire will be on the left (when the "pin" on top)
    And what does it matter to the powered device :?: and the truth is that there is no guarantee that you will always hit the phase on the left and here a simple example of a double socket.
    All in all, the idea OK but rather investors will not convince.
  • #5 17129711
    BANANvanDYK
    Help: 1167
    Rate: 2602
    RafZielak wrote:
    that the phase wire will be on the left side (when the "pin" on the top).
    Yes? And another norm in another country said that the phase on the right.
    There is no such thing as polarizing the plug / socket in Poland!
    Take into account that in PL the French system is used, where in France the TT network system is used. L and N wires are treated as active conductors, so on both of them you can expect a voltage to the local PE. In addition, the required use of RCD does not allow any active conductor to be connected to earth or PE, in particular to the housing of the device.
    Polarized nests (L and N at a specific location) are only used in several countries.
    Investors certainly will not convince. For now, there is a norm for the French system. But it is worth considering Italy, where two types of sockets are used (Italian and German Schuko systems) depending on the region, but there is no rule from it anyway.
    Certainly there should not be a problem in IT. All plugs for computers and peripherals are in the uni-schuko standard.
  • #6 17129800
    emigrant
    Help: 107
    Rate: 326
    Do not insert Chinese non-cord extension cords into sockets with a pin. Although there is a way to do it. People do notches with a knife in the plug.
  • #7 17129852
    BANANvanDYK
    Help: 1167
    Rate: 2602
    Do you know what I think about Chinese extension cords?
    As recently in the work, the extension socket made a short circuit such that half of the power plant did not have it, it was already Chinese ........ I do not intend to take it. The element to which the cord is screwed is detached. In the new one - the element is poorly pressed and loose. Producer Czech Republic (Made in PRC).
  • #8 17129866
    emigrant
    Help: 107
    Rate: 326
    What you think is completely irrelevant. People buy it because it is available for sale. To choose to color.
  • #9 17129930
    BANANvanDYK
    Help: 1167
    Rate: 2602
    It is a pity that not enough people and institutions control it. Such Chinese extension cords, power cords etc. are not compliant with the standards. Do you see a PE vein there? Do you see a 0.75 mm? wire there? The use of such conductors may cause a fire as well as electric shock (no PE, PCV armor that breaks easily).
  • #10 17129955
    emigrant
    Help: 107
    Rate: 326
    Two months ago I was in a shop where there was a corner with wires. There were some wires of different cross-section (brown, blue). I'm asking a guy why it's lying? It lies because there is a customer demand for such wires. So much in the subject.
    In addition, the first better warehouse with your website https://www.tim.pl/wyszuki/wyniki/?q=ydyp+2x2.5&p=1&category=ALL
  • #11 17130321
  • #12 17130844
  • #13 17131063
    zetdeel
    Help: 719
    Rate: 884
    WojcikW wrote:
    If someone wants to set up a Schuko socket, it is obligatory to set up an English socket next to it ...
    And why not Danish? When you look at the nest, the humor immediately improves. :D
    WojcikW wrote:
    ... An additional advantage of the English socket (such a bonus) will be the fuse in the plug. It will be fun, because such a fuse can be borrowed.
    E there. A real fun will be how you can find the right diameter nail. Cut the pliers and insert instead of a fuse. :D :D :D
  • #14 17131190
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    For me, total nonsense, I personally think that it is a hypertext form over the content, but the choice is yours :D
    Why enter the additional Schuko sockets, since both of them do the same in the same way? The latter "Belgian" are more universal.
  • #15 17138387
    BANANvanDYK
    Help: 1167
    Rate: 2602
    In some respects, even better systems would be where the plug has a protective contact in the form of a protruding pin such as https://en.wikipedia.org/wiki/File:Israeli-type-H-plugs-and-socket.jpg. Such a grounding plug can not be plugged into a socket that does not have an earthing connection. Not with us, people unknowingly deprive themselves of protection by connecting the devices in the first class of protection to the socket without grounding. Unless someone without permission replaces the socket, and the installation without a "zero" or PE. But that is not the point.
    I want to point out that the predominant area of Europe applies the Schuko standard, so why should we be different and apply the Franco-Belgian standard. Accessories in the Schuko standard are normally available for purchase in Poland (and produced at us), unlike UK accessories and other more unusual ones.
    Some have 10 points in their room in their new homes, one every 2 meters, so are we talking about adding additional sockets? Of course, you can all change to Schuko, and if you get a device of the French standard then you can use the adapter.
    However, at the time of repairs, I will start exchanging sockets for Schuko.
  • #16 17138408
  • #17 17138471
    PiotrPitucha
    Help: 201
    Rate: 424
    I like the Swiss system :) As I saw in the hotel, I fell in love with this system. It is a pity that it is not compatible with other sockets, but the possibility of inserting a typical size three plugs with a grounding pin is just as interesting as Swiss watches.
    This is what https://de.wikipedia.org/wiki/SEV_1011 looks like
  • #18 17138481
    Łukasz-O
    Help: 654
    Rate: 4292
    Budego Your installation and you will use it. You want to make your life difficult with your will passes :D
    I close.
The discussion centers around the adoption of Schuko sockets in Poland, highlighting their compatibility with existing uni-Schuko and Europlug standards. Participants express concerns about the current electrical installations in Poland, particularly regarding grounding and safety. The advantages of Schuko sockets include ease of plug insertion without orientation issues and compatibility with a wide range of devices. However, there are debates about the existing French system's prevalence and the potential challenges in transitioning to Schuko. Some participants advocate for the Schuko standard due to its widespread use across Europe, while others emphasize the need for proper electrical safety measures and standards compliance. The conversation also touches on the quality of extension cords and the risks associated with non-compliant products.
TL;DR: Two socket systems are used in Italy; "There is no such thing as polarizing the plug/socket in Poland." This FAQ helps Polish homeowners and installers decide if adopting Schuko improves safety, fit, and device compatibility with CEE 7/7 and Europlug. [Elektroda, BANANvanDYK, post #17129711]
Why it matters: Choosing the right socket type reduces adapter hassles, avoids lid-fit issues, and preserves protective earthing for Class I appliances.
  • Poland’s standard is Type E (French/Belgian) with a protruding earth pin; Schuko (Type F) dominates much of continental Europe. “E” and “F” are mechanically different. [“AC power plugs and sockets – Type E”]
  • CEE 7/7 (uni‑Schuko) plugs fit both Type E and Type F sockets, keeping mixed homes usable without adapters. [“CEE 7/7 plug”]
  • Schuko (Type F) sockets/plugs are typically rated 16 A at 250 V AC. [“Schuko”]
  • Europlug (CEE 7/16) fits both E and F, but is light‑duty, typically up to 2.5 A. [“Europlug”]
  • Poland does not enforce L/N polarization; plug orientation is not fixed in E or F systems. [Elektroda, BANANvanDYK, post #17129711]
What’s the practical difference between Poland’s Type E and Schuko (Type F)?
Type E uses a protruding earth pin in the socket. Schuko uses side earthing clips on the socket walls. Both are common 230 V systems, but they earth differently. Many modern plugs are hybrid CEE 7/7 to fit both. That preserves compatibility during upgrades. [“AC power plugs and sockets – Type E”]
Will my CEE 7/7 “uni‑Schuko” plug work in Poland without an adapter?
Yes. CEE 7/7 plugs are designed to mate with both Type E and Type F sockets. They also carry the common 16 A/250 V rating for general household loads. This is why many PC and appliance cords terminate with CEE 7/7 today. [“CEE 7/7 plug”]
Does Schuko fix the phase‑on‑the‑left/right issue in Poland?
No. Poland does not enforce fixed L/N orientation, so rotation concerns are moot. “There is no such thing as polarizing the plug/socket in Poland!” Devices must work safely regardless of insertion. RCDs and proper PE matter far more than phase side. [Elektroda, BANANvanDYK, post #17129711]
Which earthing systems (TN‑S, TN‑C‑S, TT) does Schuko work with in PL?
Schuko works when the protective contact is correctly connected to PE. In TT, RCDs are required, and both L and N are considered active. Orientation is irrelevant. Verify PE continuity before swapping sockets on older circuits. [Elektroda, BANANvanDYK, post #17129711]
Can I mix Schuko and Type E sockets in one room during a remodel?
Yes. Many users install both to keep flexibility. Italy even uses two systems regionally. Label circuits, keep protective earth continuity, and use CEE 7/7 plugs where possible to avoid adapters. [Elektroda, BANANvanDYK, post #17129711]
Is Schuko more convenient for outdoor flip‑lid (“hermetic”) boxes and double outlets?
Often yes. Without a center earth pin, Schuko avoids lid interference and upside‑down blocking in doubles. Timers and bulky power supplies seat more easily. This reduces the need for specialized housings. [Elektroda, BANANvanDYK, post #17125022]
Do I need adapters for older Polish Type E plugs if I switch to Schuko sockets?
Legacy Type E plugs that rely on the earth pin won’t earth in a pure Schuko socket. Use E/F dual‑standard outlets or a safe, certified adapter. Many modern plugs are CEE 7/7 and need no adapter. [“AC power plugs and sockets – Type E”]
Will Europlug (CEE 7/16) devices work in both Type E and Schuko?
Yes. Europlugs fit E and F sockets and are intended for low‑power devices. They are typically rated up to 2.5 A, so avoid heaters or heavy loads with Europlug cords. [“Europlug”]
Are cheap two‑core extension cords safe for Class I appliances?
No. Lacking PE and often using thin conductors, they can raise shock and fire risk. Users report noncompliance and failures with such cords. Always choose grounded extensions for Class I devices. [Elektroda, BANANvanDYK, post #17129930]
Is notching a plug to bypass the French earth pin safe or legal?
No. People do this hack, but it defeats earthing and compromises insulation. It also violates product conformity. Replace the plug with a proper CEE 7/7 or use a compliant adapter instead. [Elektroda, emigrant, post #17129800]
How do I migrate a room from Type E to Schuko safely?
  1. Verify PE continuity and test the RCD, especially on TT systems.
  2. Choose dual E/F (“universal”) sockets or pure Schuko as needed.
  3. After installation, test socket wiring and PE with a socket tester. “Both L and N are treated as active conductors.” [Elektroda, BANANvanDYK, post #17129711]
Will my PC power cords and monitors fit Schuko outlets?
Yes. Most IEC C13/C14 equipment leads in Europe end with CEE 7/7 plugs. These fit both E and F sockets without issue. IT setups migrate cleanly to Schuko. [Elektroda, BANANvanDYK, post #17129711]
Should I also install UK (Type G) sockets at home?
Only if you use UK equipment. Type G plugs include a cartridge fuse and are bulkier. As one user noted, “an additional advantage… will be a fuse in the plug.” They are not standard in Poland. [Elektroda, Anonymous, post #17130844]
Are Danish or Swiss sockets worth considering in Poland?
Not usually. Swiss SEV 1011 sockets are elegant but not compatible with E or F. Adding nonstandard systems increases cost and adapter needs for little gain. [Elektroda, PiotrPitucha, post #17138471]
