[Solved] Exploring Single-Function Heaters with Closed Combustion Chamber for Tap Water Heating
krakarak 4650 6
  • #1 17127327
    krakarak
    Help: 681
    Rate: 1846
    I am looking and looking for and what I will find, it turns out that it is a central heating boiler with DHW ...
    And I only need a single-function heater / stove to heat tap water with a closed combustion chamber.
    I have no nerves anymore.
    And hence my heartfelt request to those who have bought or know what to buy - the heater is to be used only for heating hot water for the bathroom (shower and faucet in the sink) and for the kitchen.
    If it can work (what condition?) With a 200 liter container, it would also be nice. Gas Lw (GZ-41.5).
    Anything with Termeta? Do they have outlet water temperature control and can it be set, and the heater itself doses the amount of gas needed to achieve it?
    I am asking for advice.
  • #2 17127388
    nuszek
    Level 30  
    Help: 123
    Rate: 389
    Uncle Google "gas water heater with a closed combustion chamber" - there are several dozen types.
  • #3 17127398
    krakarak
    Help: 681
    Rate: 1846
    @nuszek could you not litter the topic with nonsense without reading its contents? ... Thank you.
  • #5 17128990
    nuszek
    Level 30  
    Help: 123
    Rate: 389
    You have nothing to thank for, I just gave you what you need to look for, but as I can see, you have to put it on a tray, while your friend interferes with the topic and does not contribute anything!
    Please go to the search engine:
    1. https://www.junkers.pl/produkty/przygotowanie...azowe-podgrzewacze-przeplywowe/wt-14-am1.html
    2.https://www.termet.com.pl/produkt/aqua-comfort-turbo-gt-19-03/28
    3.https: //www.termet.com.pl/produkt/aqua-comfort-turbo-gt-23-03/29
    4. With a container: http://www.e-term.pl/ariston-sga-fb-80-gazowy-podgrzewacz-wody-003043.html
    5.http: //www.tukado.pl/produkt-21-Termet_Aqua_Comfort_TURBO_GT-23-03_(230_kW)_-_Gazowy_podgrzewacz_wody_zamknieta_komora-13686077893124-13406309182750.html
    and so on...
    ps. I did not provide links, because today they are and tomorrow is not.
  • #6 17129016
    krakarak
    Help: 681
    Rate: 1846
    Stop writing your mischievous idiocy!
    I can search for myself, I expected someone who has already installed such heaters to contact and can advise who to install and not how to find them on the Internet!
    Do you have one of them installed in your home? ... No. Do not show that you are a complete layman, because I managed to get to know it by reading your dubious achievements on Elka.
    If anyone ever asked you, Termet does not produce heaters with a closed combustion chamber intended for Lw gas, so link 2, 3 and 5 is useless and do not recommend it to me! But I have already established this by calling Termet.
    The same with link No. 1 - only GZ-50, conversion as an additional paid option.
    In links with Termet you duplicate your recklessness.
    Your posts are completely useless !!!
    I did not get any help and advice. No changes on Elka. Gimbase and sandbox ...
  • #7 17129053
    krakarak
    Help: 681
    Rate: 1846
    Added after 15 [minutes]:
    My expectations as to the knowledge of electrode workers turned out to be too high.
The discussion revolves around the search for a single-function gas heater with a closed combustion chamber specifically for heating tap water. The user expresses frustration in finding suitable models, as many options appear to be central heating boilers with domestic hot water (DHW) capabilities. They seek recommendations for heaters that can efficiently heat water for bathroom and kitchen use, ideally compatible with a 200-liter container and operating on Lw gas (GZ-41.5). Responses include links to various products, but the user criticizes the suggestions, particularly those from Termet, stating that they do not manufacture heaters for Lw gas with closed combustion chambers. The user emphasizes the need for firsthand installation experiences and practical advice rather than just product links.
