Acer Spin 1: How to Use 200GB SD Card as Internal Memory - Diskpart Script Issues
jacolp 11781 2
  • #1 17134689
    jacolp
    Rate: 9
    I bought Acer spin 1, unfortunately it has only a 32GB disk. So I bought a 200GB memory card and can't assemble it as a hard disk. I used this guide:
    http://www.altcontroldelete.pl/artykuly/karta-microsd-jako-wirtualny-dysk-w-windows/
    Everything works, except for self-assembly. My diskpart doesn't read the script at all. After entering the commands "from hand" the disk appears, while after calling the script, I see the list of commands.
    Anyone know what could be the reason?
  • #2 17141891
    lefuu
    I have exactly the same problem, I also used this guide - can someone more stranger in programming advise where the error is? Manually assembles without a problem but automounting doesn't work: / Did you manage, buddy?
  • #3 17141933
    jacolp
    Rate: 9
    Hey,
    I didn't manage. I called a registered IT specialist in my city. He explained to me that I do not need to have a local disk from an SD memory card if I just want to upload applications or download any files. All this can be saved to external memory. It would be different if I wanted to upload, e.g. windows, to this memory, I would have to have local memory, from what "professional" said it is not recommended, the computer will "silent" and you can damage the card (he mentioned a few reasons but I do not remember) . For now, I turned off automatic updates (there is a guide on how to disable it on windows 10), I just put a 200GB card and I installed everything on the card without any problem. At the moment it is enough for me, I will come back to the problem when the stairs will appear.
    Greetings.
