Can the SSD in an Acer Spin 1 SP111-32N be upgraded or replaced?
Usually no: the factory “SSD” in this model is actually eMMC flash soldered to the motherboard, so it is generally not user-replaceable unless you have BGA rework tools [#17634838] The only practical upgrade path is to check whether your specific board has an M.2 slot; if it does, a normal SSD may be added there, but some low-cost versions (especially the 32GB ones) may not include the socket [#17634838] One reply notes that this series exists in 32GB, 64GB, and 128GB variants, so storage size depends on the exact configuration [#17634296] Another post identifies the platform as Apollo Lake and mentions a 64GB eMMC version, which supports the idea that the onboard storage is part of the board rather than a standard removable drive [#17635105] If you want to know for sure, the advised method is to remove the cover and inspect the connector area, because the presence and type of M.2 slot must be verified on the actual unit [#17634838]
Your answers are extremely factual. Thank you, but neither I nor the others, possibly interested, need such. I am asking because I do not know whether it is possible in this model, whether the SSD is not soldered or not an integral part of the motherboard. As for what the equipment is under warranty, I will not start it if someone knows that it can or not. If it is possible, I will do it, if not, I will not disassemble the equipment. I am not stupid and I know I can check, but such a test may cost me a loss of the warranty. So I ask those who know if it is possible, because in previous models spin 1 sp111-31 it was possible, and here I did not find info anywhere at Uncle Google. So before you start commenting in the "probably" type and lecture about the obvious, do not write, because it does not help anyone. Have a nice evening.
If it's hard for you to enter an interesting phrase in Google, what responses do you expect? https://www.google.com/search?client=firefox-...grade&oq=acer+spin+1+sp111-32n+ssd+&gs_l=psy- ab.3.0.0i22i30.2899.7845..9234 ... 0.0..0.178.751.0j5 ...... 0 .... 1..gws-wiz ....... 0j0i71j0i203.D-oacSfh33Q By the way, instead of crying now that you don't have space and the equipment is under warranty, you had to think BEFORE you buy it.
well, that you have gone so interesting after this link, smart guy? Did you find info about the 32n version? But to lecture you are the first ... Eh, it's a pity to talk.
Welcome. The original "SSD" - it's actually a flash memory card soldered onto the motherboard. The SSD wheel it didn't really lay, I wonder why some people don't call it by name eMMC, they just write SSD (it's about sellers' offers). The exchange is probably possible if you like and know how to solder BGA chips. Generally, without tools for this, assume that "SSD" is non-replaceable.
However, it is worth seeing if there is an M.2 slot on the disc, then there would be a chance to add a normal, correct SSD disk.
The best way would be to disassemble the laptop - it doesn't look very difficult with this model and - as long as there are no visible seals - it probably won't interfere with the warranty. I found a review of this series (with a larger memory card, maybe with a different processor - because they were with Pentium and Celeron), but there are photos of the interior, it will probably be the same:
When enlarging one of the photos, we have the following view:
After the key in the slot, I can guess that 2280 M.2 SATA drives (or PCIe x2.0) should fit, but it's worth making sure. With budget models, probably SATA.
It is also worth seeing if there is such a socket specifically in the colleague's copy. It cannot be guaranteed that in every series it will be (perhaps the super low-cost versions with Celina and 32GB flash have this slot cut out for the sake of savings). In one of the comments under the review, it says that the user did not have a socket.
So - there is a chance, but it's worth taking the cover off, it's not a breach of warranty. By the way, it is worth taking a detailed photo of this connector (you will be able to judge whether it is SATA or PCIe x2 by the paths, if you could not find it in the specification. SATA and PCIe x2 drives have cutouts that physically fit such a slot, hence the lack of certainty. So, if the socket was found - a good, sharp photo of the area of the connector itself may reveal anything, as long as the paths are visible.
* model opisany Link najdroższa wer. to (Pentium N4200 CPU (4 Core™ /1.1GHz) and SSD(EMMC ) 64GB of storage... InsydeH20 v1.03)
kbc IT8987E
p.s
Bios jest ciekawy
- w Setting: SecureBoot disabled, F12 and NetworkBoot enabled
* odblokowanie Link - added an UEFI file as trusted for executing from the USB with installed Ubuntu in BIOS
- created bootable USB with rufus or directly from a computer with Ubuntu installed
- Link_ check 32 or 64 bit OS
Mimo słabych parametrów jest drozszy niż np. Lenovo Yoga 710 11 (Yoga 3 11)
Na SoC N4200 bywał LA-B301p / X541NA MAIN BOARD REV 2.1
Create an account, log in here and be active on the forum — ads won't appear. Earn points for registering and replying.
The discussion centers around the possibility of upgrading the SSD in the Acer Spin 1 SP111-32N model. Users note that the device typically comes with eMMC storage, which is soldered onto the motherboard, making it non-replaceable without specialized skills in soldering BGA chips. However, there is speculation about the presence of an M.2 slot that could allow for the addition of a standard SSD. Disassembling the laptop is suggested as a way to check for upgrade options, but caution is advised regarding warranty implications. Previous models in the Spin 1 series had upgradeable SSDs, leading to uncertainty about the SP111-32N's capabilities. AI summary based on the discussion. May contain errors.
TL;DR: Many SP111-32N units ship with 32GB eMMC, and “The original 'SSD' is actually a flash memory card soldered onto the motherboard.” If your board has an M.2 2280 slot, you can add a real SSD; some low‑cost units lack it. [Elektroda, dt1, post #17634838]
Why it matters: SP111-32N owners learn safe, warranty-aware ways to expand storage and avoid incompatible SSD purchases.
Some SP111-32N boards include an M.2 2280 slot; the cheapest configurations can omit it entirely. [Elektroda, dt1, post #17634838]
Budget-tier boards implement SATA in the M.2 slot; confirm any PCIe x2 support before buying NVMe. [Elektroda, dt1, post #17634838]
Disassembly involves removing the bottom cover; absence of seals avoids warranty conflicts—photograph the connector area. [Elektroda, dt1, post #17634838]
Can I upgrade the SSD in the Acer Spin 1 SP111-32N?
Yes, but not by swapping the soldered storage. The built-in eMMC is part of the motherboard. Replacing it needs BGA rework skills and tools. Treat it as non-replaceable. Look for an unused M.2 slot on the board. If present, you can add a standard M.2 2280 SSD as an upgrade path. [Elektroda, dt1, post #17634838]
Does my SP111-32N have an M.2 slot, and how do I check?
Not every unit has the socket. Some low-cost 32GB configurations omit it entirely. Remove the bottom cover and inspect the board. Look for an M.2 2280 connector area and take a sharp photo of the traces. Then confirm SATA versus PCIe x2 routing. How-To: 1. Power off and disconnect AC. 2. Remove the bottom cover screws and lift the panel carefully. 3. Locate the M.2 area; photograph it to identify interface. [Elektroda, dt1, post #17634838]
What SSD form factor and interface fit if the slot exists?
The slot takes 2280-length M.2 drives (80 mm). Treat it as SATA unless you confirm PCIe x2 support. NVMe modules physically fit but remain undetected in SATA-only sockets. “With budget models, probably SATA.” [Elektroda, dt1, post #17634838]
Will opening the case void my warranty?
Check for warranty seals on the bottom cover. If none are present, opening the cover does not interfere with warranty on this model. Take care not to damage labels or plastics while inspecting the slot. [Elektroda, dt1, post #17634838]
What storage capacities and CPU trims exist for the SP111-32N?
The SP111-32N-P9VD variant is listed with 64GB eMMC. It uses an Apollo Lake Pentium N4200, a 4-core 1.1 GHz SoC. Screen size is 11.6 inches in this series. Always verify your exact SKU for capacity before purchasing parts. [Elektroda, lisek, post #17635105]
Is the built-in storage a real SSD or eMMC?
It is eMMC, not a standard replaceable SSD. The chip is soldered to the motherboard and behaves differently from SATA/NVMe SSDs. “The original ‘SSD’ is actually a flash memory card soldered onto the motherboard.” [Elektroda, dt1, post #17634838]
Can I replace the soldered eMMC with a bigger one?
Technically yes, but only with full BGA rework. That requires specialized equipment, profiles, and experience. Without those, treat the eMMC as non-replaceable and plan an M.2 add-on instead. [Elektroda, dt1, post #17634838]
Is there a teardown video I can follow to open the Spin 1?
Yes. A referenced teardown shows opening the SP111-32N; start viewing at 1:10 for cover removal. Use it to preview screw locations and clips before you begin. [Elektroda, lisek, post #17635105]
Will an NVMe M.2 drive work in this laptop?
Only if the board and socket route PCIe. Budget-tier SP111-32N boards implement SATA in the M.2 slot. NVMe drives can physically fit due to identical keying, yet remain invisible on SATA-only sockets. Confirm by inspecting traces and documentation. [Elektroda, dt1, post #17634838]
Where can I see internal photos to locate the M.2 area?
The linked review includes clear interior photos of this series. Use them to identify the M.2 connector location and keying before opening your unit. Keep in mind some units omit the socket entirely. [Elektroda, dt1, post #17634838]
Can I install Linux or Windows from USB on this model?
Yes. The InsydeH2O BIOS exposes Secure Boot controls, an F12 Boot Menu, and “add trusted UEFI file” support. Users boot Ubuntu after adding the UEFI file as trusted. Create bootable media with Rufus or a Linux machine. [Elektroda, lisek, post #17635105]
What if my board has no M.2 socket?
Then there is no internal upgrade path without BGA rework. Use the soldered eMMC as-is or choose external storage alternatives. Some SP111-32N batches ship without the M.2 socket to reduce cost. [Elektroda, dt1, post #17634838]
