VW Golf V (2005, 1.6L, 102HP) - Engine Temperature Stuck at 75-80°C: Thermostat Issues?
pawel9502 12009 3
  • #1 16513823
    pawel9502
    I have a VW Golf V from 2005, petrol, 1.6, 102HP engine. I have had an engine temperature problem for some time. Until some time everything was fine, even 90 degrees. One day it warmed up to 75-80 degrees Celsius and since then this temperature has been maintained with normal driving. However, when I stand in a traffic jam, the temperature then reaches these 90 degrees.
    I searched a bit on the internet what could be the reason. Many people point to a faulty thermostat.
    So gentlemen, what do you think could be causing this situation? Is it actually most likely a thermostat? If anyone can advise where I can find exactly this thermostat, I would very much be asking for help. I searched and looked, but I did not find it, and I think I would be able to replace it myself :) thanks in advance!
    Ricoh_220
    Help: 464
    Rate: 754
    The reason the thermostat does not close you have a large coolant circulation all the time.
    https://www.google.pl/search?client=opera&q=V...8&oe=UTF-8#q=vw+golf+5+1,6+wymiana+termostatu
    Zakład techniki biurowej"Kserograf" .Serwis kserokopiarek i urzdzeń marki ricoh
    Bronowicka 73, Kraków, 30-091 | Tel.: 603XXXXXX (Show) | Company Website: https://kserograf.e.pl
  • #3 16513866
    Staszek49
    Help: 228
    Rate: 1140
    Maybe check the coolant level at the beginning and bleed the cooling system after turning on the heating to max. If this does not help, connect the car to the computer and check if the liquid temperature in the engine is close to the indications on the clocks, because the 2-pin temperature sensor may distort the indications. If you decide to replace the thermostat, check the review materials on the forum beforehand.
  • #4 16597942
    pawel9502
    Replacing the thermostat helped. Thank you.
