[Solved] WiFi does not work - the network card does not have the correct IP configuration
shadyyo313 3810 8
  • #1 17142413
    shadyyo313
    I have a problem with WiFi connection on one laptop. It certainly doesn't involve a router, because exactly the same problem appeared in Germany. Now, after returning to Poland, there is exactly the same problem.
    In the bottom right corner there is a yellow exclamation mark with the information "Unidentified network. No internet access", but after clicking this button WiFi is enabled and the connection selected, however with the message "Limited access". In turn, the network troubleshooting tool shows the message: The Wi-Fi network adapter does not have the correct IP configuration .
    I would add that this problem appeared quite suddenly, and all other devices on the network are working properly. Although it may have something to do with updates, because my dad (it's his laptop) noticed that the System Restore option worked several times until before any updates and WiFi could work for several days, but then the same error suddenly reappeared.
    I tried everything. Among others entering in cmd all commands starting with ipconfig and netsh, or reinstalling drivers. With the driver I had a problem that after clicking on the network card in the device manager and later Uninstall, after restarting the computer, it automatically installed itself with this driver. In the end, however, I uninstalled, and immediately installed a new driver (downloaded from another computer from the network) and after restarting the computer finally shows the newly installed one. But the problem still exists.
    Can You help me? Enter the result of entering comedy ipconfig \ all?
    makosuu
    Help: 369
    Rate: 370
    Yes.
  • #3 17142437
    shadyyo313
    makosuu wrote:
    Yes.
    WiFi does not work - the network card does not have the correct IP configuration WiFi does not work - the network card does not have the correct IP configuration
    All in all, after installing this driver, suddenly the network is called Wi-Fi 3 (previously it was simply called Wi-Fi) and now after ipconfig / all more of all this is shown. I don't know why, but even if there was one network there, it was the same problem.
    makosuu
    Help: 369
    Rate: 370
    The card does not get an address from DHCP. It works normally on other devices, and does this card work on another network?
  • #5 17142511
    shadyyo313
    As I mentioned - other devices (computer, telephones) work normally on this network. Similarly, this card had exactly the same problem being in a different network (in Germany).
    KOCUREK1970
    Help: 3860
    Rate: 5488
    @ shadyyo313
    Enter the LAN IP address in the router for this card, add the MAC card of the card if required, restart the computer - it should help.
  • Router LAN IP assignment and MAC binding suggestion
    #7 17149104
    shadyyo313
    KOCUREK1970 wrote:
    @ shadyyo313
    Ultimately, however, I gave up and simply did a system reinstall. The problem was no longer after the first start of the system. Before I wrote here, I was sitting on it for about a week and that's why it was beyond my strength.
    But thanks so much for your willingness!
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Apparently it is breaking some update for the system.
    It is worth doing it anyway - whatever happens, IP will always be the same.
  • #9 17650839
    shadyyo313
    Reinstallation of the system
The user is experiencing WiFi connectivity issues on a laptop, indicated by a yellow exclamation mark and messages stating "Unidentified network. No internet access" and "Limited access." The network troubleshooting tool reports that the Wi-Fi network adapter lacks the correct IP configuration. The problem persists across different networks, including one in Germany, and may be linked to recent system updates. Suggestions from the forum include checking DHCP settings, entering a LAN IP address in the router, and reinstalling the system, which ultimately resolved the issue for the user after a week of troubleshooting.
