The "Wi-Fi" network card does not have the correct IP configuration.
Anyone_ 8232 6
  • #1 17240255
    Anyone_
    Hi!
    Namely, I've been struggling with a problem for two weeks (no internet).
    When I go into the network tab (this next to the time and date) it shows me that my internet, Wi-Fi connection (as I call it, I do not know) is limited.
    "Troubleshooting" showed that the "Wi-Fi" gateway does not have the correct IP configuration (unresolved).
    And now my questions. How to solve this problem? What could have caused him? I looked at other topics, but none of them helped me yet.
    I will add that when I enter: Network and sharing center -> Network connections -> Wi-Fi, in the "general" tab there are various information, including:
    IPv4 connections: No network access
    IPv6 connections: No network access
    And when I enter: Properties -> Internet protocol version 6 (TCP / IPv6) or Internet protocol version 4 (TCP /) -> Properties, it is set to obtain an IPv6 / IPv4 address automatically, but there is no address entered underneath IP, subnet subnet length, default gateway etc. only empty gaps. Should I do all this manually?
    This lack of internet really pains me, I count on your help. If you have any questions, please write. Greetings! :D
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    First of all, start with the description of the network you want to connect to and determine whether you enter the correct password. Other devices on the same network are working properly?
    Is the problem in one network or in all?
    If you are getting an address automatically (DHCP) then the fields described should fill in themselves once you have a Wi-Fi connection.
    You can disable automatic downloads and enter manually using adsees outside the DHCP pool.
    The connection via the wired network (RJ45) card works?
  • #3 17240455
    Anyone_
    Other devices in this network are working properly, all of them. The type of network to which you want to connect is (according to the control panel) an unidentified, public network. The problem occurs in all networks. I tried at the beginning of simple methods such as: completely turning off the router, connecting the router to the laptop, restoring drivers, updating, etc. When connecting the router to the laptop "Solving problems detected the same problem, but instead of Wi-Fi wrote about Ethernet. .
    Yes, it's automatic. Is it normal that when I do not have an internet connection, the fields are empty?
    Will it help with anything?
    I do not understand. I'm green in these matters, forgive ... Is it about Ethernet cable?
    EDIT: I think I know what's going on. I hooked up the phone to the laptop via the charger and tried to connect (like sending a net from the phone to the paw), but to no avail. But when it comes to such a device like the powerbank, I do not even have something like that.
    jdubowski
    Help: 2511
    Rate: 2804
    Anyone_ wrote:
    When connecting the router to the laptop, "Solving problems detected the same problem, but instead of Wi-Fi it wrote about Ethernet, the password is also correct.
    DHCP client or completely dispersed TCP / IP stack.
    If the problem concerns a DHCP client then we have a workaround (with all the inconvenience of using it). If the problem is with TCP / IP in general, then we will not get around this method of the problem.
    Yes, you write above that you have made the attempt and the effect is identical.
    In general - repairing the operating system - what is the system?
  • #5 17242652
    Anyone_
    Windows 8.1
    Can I do it myself, will it not be possible without the help of an IT specialist?
    jdubowski
    Help: 2511
    Rate: 2804
    The problem appeared suddenly by itself, or after installing some software?
    Repairing the TCP / IP stack is quite a "crazy" topic:
    https://www.google.com/search?q=tcpip+repair+windows+8.1
    It can be simpler to reinstall the system.
  • #7 17245448
    Anyone_
    EDIT: Okay. If I understand reinstalling the system, this is a computer refresh, right?
    And now the question. Will this delete files, games downloaded from the browser as well as photos, documents? Rip it on a pendrive?
    So I have to choose the option to refresh my computer?
    The problem appeared alone. So suddenly and simply.
    I will try your advice.
    Once everything is ripe, let me know what and how.
    I hope it works: I
The user is experiencing a "limited" Wi-Fi connection with no internet access, attributed to an incorrect IP configuration. Troubleshooting indicates issues with both IPv4 and IPv6 connections, which are set to obtain addresses automatically but remain empty. The user has confirmed that other devices on the same network function correctly and has attempted various solutions, including restarting the router and updating drivers. Suggestions from responders include checking the DHCP client, repairing the TCP/IP stack, and considering a system refresh or reinstallation of Windows 8.1. The user seeks clarification on whether a system refresh will delete personal files and how to proceed with the suggested repairs.
