Yellow Triangle: WiFi Connected but No Internet Connection Message - Router Issue
maridok 7557 3
  • #1 16488263
    maridok
    I am warning that I am green. I write with poor phone quality, so please forgive mistakes :)
    Appeared from day to day. Everyone at home is connected to one router and has an internet connection. For me, although I am connected, I have a yellow triangle next to the Wifi sign and the message "no connection with the Internet". Why?
  • Check modem access and IP assignment first
    #2 16488292
    roxio
    Help: 108
    Rate: 213
    1. Someone may have a restriction on your modem on your computer that blocks access to the internet.
    2. The modem has not assigned you the correct ip address or there is a duplicate ip address on the network
    3. Your anti-virus or firewall blocks network traffic after the upgrade
    4. Some unwanted software is blocking access to the network
    5. And many other reasons ...
    Check if you can connect from your computer to the modem, depending on the modem and configuration, addresses may be different, check the sticker on the bottom of the modem. There should be a modem address (e.g. 192.168.1.1) with login and password. And we will see what to do next
  • Intermittent Wi‑Fi drops and router access loss
    #3 16488383
    maridok
    After restarting the computer, it happens that I can go to the server side, another but only for about 30 seconds. After that the internet disconnects and until it disconnects and connects again it does not work. The Wifi icon after it stops working for some time as if it is active, i.e. showing an internet connection but after a while showing a total disconnection.
    Added after 3 [hours] 5 [minutes]:
    PS: I can't connect to the router address between these gaps. Nothing works when it comes to internet until you disconnect and reconnect.
  • #4 16489884
    KOCUREK1970
    Help: 3860
    Rate: 5488
    maridok wrote:
    Everyone at home is connected to one router and connected to the internet
    And everyone (you too) are in the same room?
    Install InSSIDera v2 / Home on your computer, and here enter the measurement result of the network - all are to be visible.
