[Solved] Toshiba 32GB USB Flash Drive: Read-Only Issue, Disk Write Protected, TV List Saving & Diskpart
tomciiu 8361 9
How can I fix a Toshiba 32 GB USB flash drive that became write-protected and throws a DiskPart I/O device error when I try to clean it?
The drive is most likely failing at the firmware or memory level, so the practical fix is usually to replace it rather than keep fighting the write protection [#17148970] You can check the controller type and memory size detection with ChipGenius to see whether recovery is even possible [#17148795] If you want to experiment and do not need the data, try deleting the partition or resetting the disk, but that will erase everything [#17144260] Another suggestion was to reinstall/reflash it from Linux [#17149020]
  • #1 17144151
    tomciiu
    I have had a problem with the Toshiba 32 GB flash drive for some time.
    It all started with the fact that when I set the list of programs to TV, I wanted to save it on a USB flash drive connected to the TV.
    After that, I connected the pendrive to the computer to upload something to it and then watch it on TV, but I could not record anything on it or remove anything from it. Formatting helped. Then I wanted to upload something new again, but again the same problem, this time formatting did not help, I was getting an error "The disk is write protected". I searched several sites for help and some tutorials. I tried to fix the problem by removing the lock by editing the registry, but everything was as it should be. Then I tried the tutorial by repairing it with diskpart. This is where I came to the halfway point and another problem arose. In the command line I entered list disk-> select disk 1 (this is a pendrive) -> attributes disk clear readonly-> clean and here after entering the celan command an error appeared: "DiskPart has encountered an error: Unable to execute the request due to a device error I / O. See the System Event Log for more information.
    Can something be done about it? Thank you in advance for any help.
    Greetings Tomek.
  • #2 17144231
    michalek1988
    Help: 68
    Rate: 181
    Have you used it before, and was it OK? Maybe you bought a defective product, then it is worth sending it back to the seller to replace or repair it.
  • #3 17144234
    tomciiu
    I've had it for as long as I can remember :D .
  • #4 17144260
    michalek1988
    Help: 68
    Rate: 181
    Isn't it feasible to delete a partition and leave it unfinished either? You can also try resetting this disk. In both cases, you will lose your data. If you don't have anything important on it and you treat it as an "educational toy", you may be able to revive it. However, if you plan to further exploit it, I strongly advise against it. Buy a new memory that you know you can use without any problems, without wondering if you can write or read the data.
  • #5 17144285
    gumisie
    Help: 1667
    Rate: 2487
    Have you tried to format via this TV (if it has such an option)? I used to have a similar problem after connecting to the Polsat decoder.
  • #6 17148530
    tomciiu
    Thanks for the answers, I will check everything in the evening and let you know what and how.
  • #8 17148970
    RS_COD
    Help: 14
    I would buy a new flash drive because it is a cheap device and this one most likely has damaged firmware or memory, so it will always be a time bomb.
    Megaserwis S.C.
    Opaczewska 43/8, Warszawa, 02-201 | Tel.: 609XXXXXX (Show) | Company Website: www.centrumodzyskiwaniadanych.pl
  • #9 17149020
    elecol
    Rate: 9
    I agree with RS_COD, I had the same, you can try to reinstall it from linux
  • #10 17179991
    tomciiu
    I replaced the pendrive with a new one :)
The discussion revolves around issues faced with a Toshiba 32GB USB flash drive, specifically regarding read-only errors and disk write protection. The user initially encountered problems when attempting to save a program list from a TV to the flash drive, followed by an inability to modify the drive's contents on a computer. Attempts to resolve the issue included formatting the drive and using the Diskpart utility, but the user continued to receive a "disk is write protected" error. Various suggestions were made, including checking for defects, formatting via the TV, and considering the purchase of a new flash drive due to potential firmware or memory damage. Ultimately, the user decided to replace the faulty flash drive with a new one.
