Unlock Write-Protected SanDisk Cruzer Blade 32GB USB Flash Drive: VID=781, PID=5567 Fix
Dynako 13845 8
  • #1 17298349
    Dynako
    I have a pen drive from SanDisk and the model is called Cruzer Blade 32GB. I've tried a lot of programs but nothing helped. It started so that I wanted to speed up the pendriva and defragmented it and from now there is a message that the disk is write-protected. All folders on it are read-only and it cannot be changed because an error pops up. VID = 781, PID = 5567
  • #2 17299157
  • #3 17299169
    safbot1st
    Help: 2719
    Rate: 1585
    @ jan345 It's just that your link is a broken pen.
    @Dynako Please screenshot ChipGenius and the effect of diskpart.
  • #4 17299368
    Dynako
    As I type the clean command in cmd, something like this pops up:
    [DiskPart has encountered an error: The request could not be completed because of an I / O device error.
    See the System Event Log for more information.]
    • Unlock Write-Protected SanDisk Cruzer Blade 32GB USB Flash Drive: VID=781, PID=5567 Fix Bez tytułu.png (68 KB) You must be logged in to download this attachment.
  • #5 17299390
    safbot1st
    Help: 2719
    Rate: 1585
    Unfortunately, ChipGenius cannot detect the controller or the memory. Try "powerfull detection" as they advise or use other software for this.
    Ultimately, you will need to get physically into the hands, to know what "Russian" firmware from flashboot.ru to use for resuscitation.
  • #6 17299545
    pidar
    Help: 1569
    Rate: 3594
    Add info (check items writable ) about this data carrier from USB Drive Info . :idea:
    • USB Drive Info v5.3.6.0.zip (454.41 KB) You must be logged in to download this attachment.
  • #7 17301613
    Dynako
    robi mi Wirtable = no {https://obrazki.elektroda.pl/4761649000_1530185345.png} I downloaded the powerfull detection program and wrote that there is no bad software
  • #9 18659076
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4260
    Maybe the defragmentation has not been completed for some reason and needs to be repeated, same program . During defragmentation, the disk's condition is such that other programs cannot read it properly and the attempt to write it will break so that its file system cannot be repaired, at most formatted - therefore a well-done defragmentation program should, if possible, at the beginning, block the recording until it is completed. Consequently, if the defragmentation has not finished, the disk is read-only, and not reliable.
The discussion revolves around a SanDisk Cruzer Blade 32GB USB flash drive that has become write-protected after an attempted defragmentation. Users suggest various troubleshooting methods, including using software like ChipGenius and DiskPart to diagnose and potentially fix the issue. Some users report I/O device errors when attempting to clean the drive, while others recommend checking the drive's writable status and considering warranty options if the device is still under the manufacturer's coverage. There are also suggestions to repeat the defragmentation process, as incomplete operations may lead to the drive being read-only.
