Podofo 7018b - How to connect radio 7018b to the Hyundai i30 factory radio stati
Pavel7593 37620 4
  • #1 17150780
    Pavel7593
    Hello, please help me step by step to connect the radio 7018b in place of Hyundai's factory radio i30 2010. I found the internet connection diagram of the factory radio and attach a description from the new radio auction. I also want to connect in such a way that the steering wheel controls work (the radio has this function). And that the factory socket usb in the car was still active (charging)
    I am asking for information as well as which cable to connect with, I will be very grateful.
    Factory Radio: Podofo 7018b - How to connect radio 7018b to the Hyundai i30 factory radio stati
    New radio:
    Podofo 7018b - How to connect radio 7018b to the Hyundai i30 factory radio stati Podofo 7018b - How to connect radio 7018b to the Hyundai i30 factory radio stati
    Description from the auction site:
    important information before installation:
    yellow line (for memory wire) connected to a positive DC battery positive, the device will have a memory function.
    red line pick key for ACC line, this line is also positive, power switch control. black wire connected to the negative power pole.
    The blue line connected to lift the antenna or REM subwoofer control wire, if you have not connected, the cloth wrapped up with rubber.
    the other eight wires (gray white green purple) are the speaker lines, a group of colors corresponding to a pair of speaker lines (positive and negative).
    Please pay attention to check whether the speaker cable of the original car in the event of contact of iron (original car speaker metal welding wire, or speaker only thow out line, called the iron contact). Iron contact will cause our high power machine without sound, please test it with a multimeter before installation, in case of iron contact, please disconnect and then install.
    Reminder:
    1. You can not use the original car plug directly connected to our new machine, do not fit will lead to the machine burned, part of the machine can be shared please contact customer service.
  • #2 17150820
    pp74
    Help: 186
    Rate: 283
    This radio does not support or control the steering wheel, nor does it lead to a USB socket in the car
  • #3 17150855
    Pavel7593
    And an orange cable? And the USB is not about getting out of the radio just to have the voltage in this socket in the car or is it connected?
    I am just asking for information on how to connect these cables so that the radio will work :) ?
    In the sense
    The yellow cable for this, for example, No. A4, blue for this number, etc. does not want to collapse during assembly.
    Added after 8 [minutes]:
    Is it possible to connect this radio with an ISO beam?
    pp74
    Help: 186
    Rate: 283
    1. The plug with speaker outputs remains unchanged (it remains original from the car)
    2. The voltage for USB comes from the original radio so you will lose it (unless you take it out of the port of the new radio)
    3. Power plug according to the picture Podofo 7018b - How to connect radio 7018b to the Hyundai i30 factory radio stati
    4. Orange is yes to control but no one wrote that the input is compatible with your car and risking in the dark may end badly.
  • #5 17152876
    Pavel7593
    I still have a question, and if I connected this radio to original hyundai cables? there are cubes such as ISO only replaced by a yellow cable with a red one, so there may be problems with the memory of the radio then if it was replaced, the 2 cables would be ok? did not sleep radio or installation or something connected with these original cables?
