[Solved] "You have blocked access to the Internet" ERR_NETWORK_ACCESS_DENIED
stalker2000pl 24687 7
  • #1 17161890
    stalker2000pl
    Hello, I have an internet problem on my pc. The point is that it does not exist at all, even when you connect the internet from your phone via USB. The problem appeared when I installed virtualbox and then I turned off the computer. This does not only affect the browser but the entire system. The router's wine is not because it is just writing from this wifi network.
  • #2 17161915
    bestboy21
    Level 40  
    Help: 566
    Rate: 782
    A colleague will enter the device manager, knock out all network cards (virtual ones too) and restart the computer.
  • #3 17162229
    stalker2000pl
    Still the same
  • #4 17162613
    bestboy21
    Level 40  
    Help: 566
    Rate: 782
    You cry and you do not give any data.
    Logs with FRST?
    What anti-virus on the computer?
  • #5 17162621
    stalker2000pl
    Logs with FRST?
    1.malwarebytes, I uninstalled it
    2. How do I download frst since I do not have internet, the more I do not have how to send logs
  • #6 17162624
    bestboy21
    Level 40  
    Help: 566
    Rate: 782
    Look at you, write on the forum, so you can download the phone and upload it via a USB cable to the computer, and even if not through the cable, through the memory card.
    Have you just tried to restore the system to the day before installing virtuala?
  • Suggesting system restore before virtual machine install
    #7 17162633
    stalker2000pl
    It is not possible because I do not play backups, and as for the logs from frst, they will be there soon
    EDIT here are the logs in the attachment
    • FRST.txt (51.17 KB) You must be logged in to download this attachment.
    • Addition.txt (65.31 KB) You must be logged in to download this attachment.
  • #8 17163469
    stalker2000pl
    It was enough to turn off the vpna firewall (it makes it impossible to connect to the internet when we do not connect to their servers) thanks for the lost data on VB.
    • "You have blocked access to the Internet" ERR_NETWORK_ACCESS_DENIED 15235268874111606281444.jpg (4.51 MB) You must be logged in to download this attachment.
    • "You have blocked access to the Internet" ERR_NETWORK_ACCESS_DENIED 1523526865364528115400.jpg (1.82 MB) You must be logged in to download this attachment.
The user experienced a complete loss of internet connectivity on their PC after installing VirtualBox, which affected the entire system. Initial troubleshooting steps included disabling all network cards via Device Manager, but the issue persisted. The user had uninstalled Malwarebytes and faced difficulties downloading necessary diagnostic tools due to the lack of internet access. Suggestions included using a phone to transfer files and considering a system restore, but the user did not have backups. Ultimately, the problem was resolved by disabling the VPN firewall, which was blocking internet access when not connected to the VPN servers.
