Windows 10 Stutters & Freezes after Interrupted Reset - Unresponsive Desktop & Taskbar Issues
Garosek 5811 10
  • #1 16945699
    Garosek
    Good hello, everyone has a little problem
    In 21% of the format / reset windows 10 I turned off the computer because it stood at 21% of 6 hours and now as if after turning off and turning on the computer normally I got windows set se go normally it was all cleaned, the whole disk there was something 2 GB ripped because windows, but after logging in to the computer, it tries to click something on the desktop, some applications, even the taskbar with windows hangs, stutters and I do not know what to do, I just can not click anything, the cursor stands without a twitch and you can not do anything: start the task sage or something, I need to reset the computer by holding down the button or lecturing from the outlet, someone knows what it could be: v thanks in advance
    Ps: sorry for my language and writing style but unfortunately I don't live in Poland
  • #2 16945723
    Pedros050
    Help: 2471
    Rate: 3901
    Hello. Do you have the system on the wine list 10? Then start from the beginning of the full disk format, delete all partitions and only in the clean system.
  • #3 16945732
    Garosek
    Unfortunately, I don't have one on the CD, the computer was already bought with windows inside
  • #4 16945748
    Pedros050
    Help: 2471
    Rate: 3901
    Have you deleted the Recovery partitions? And the key is digitally assigned. All you have to do is pull the win 10 system from Microsoft and burn it to an ISO image on a disc or to Pen.
  • #5 16945754
    mati211p
    HDD and data recovery specialist
    Help: 2584
    Rate: 1129
    SMART disk sweep.
  • #6 16945796
    Garosek
    mati211p wrote:
    SMART disk sweep.
    Sory, but what is that ?? ; D
  • #8 16945803
    Garosek
    And how would I have to fire with pen if I can not open anything because it will stop: c?
  • #9 16945824
    Pedros050
    Help: 2471
    Rate: 3901
    It's first on your second computer like download win 10 Home 64bit because you probably have one?
  • #10 16945840
    Garosek
    I have to tell you that I am the biggest amateur about computers: v you could send some link to a movie how to do it
    C
✨ The discussion revolves around a user experiencing stuttering and freezing issues with Windows 10 after an interrupted reset at 21%. The user reports being unable to interact with the desktop or taskbar, requiring forced shutdowns. Responses suggest performing a complete disk format and reinstalling Windows 10, with recommendations to delete recovery partitions and use a USB drive to install the OS. Users also mention the need for SMART disk checks and provide links to resources for downloading Windows 10 and instructional videos for the installation process.
