Peugeot 307 - Where is the drain and check valve for the oil change in the gearb
gsmowiec 42342 1
  • #1 17189310
    gsmowiec
    User under supervision
    Help: 27
    Rate: 128
    ] Peugeot 307
    1.6 gasoline
    2001
    I have such boxes, I can not find a drain and control plug to change the oil in gear.
    I found one cork that is behind the left wheel arch or is it a drain plug? (it is not screwed from the bottom of the box just from the side.
    Where is the control plug?
    Peugeot 307 - Where is the drain and check valve for the oil change in the gearb [/ Url
    Peugeot 307 - Where is the drain and check valve for the oil change in the gearb Peugeot 307 - Where is the drain and check valve for the oil change in the gearb [url=https://obrazki.elektroda.pl/7215229900_1524742226.jpg]
    mario 77
    Help: 66
    Rate: 335
    The control plug you have in the first picture and the drain on the differential housing at the bottom under the axle, not from the underside only from the side.
