Whirlpool ADG789 Dishwasher - Door does not close shut on one side
lucas13 10488 8
  • #1 16209252
    lucas13
    Rate: 38
    As in the topic Whirlpool ADG789 dishwasher. On one side, the door protrudes about 1cm-1.5cm, so steam comes out at some point ... Is there any way to adjust it (e.g. hinges)? I replaced the springs and cables, but you couldn't see anything where you could adjust the hinged door ...
    Whirlpool ADG789 Dishwasher - Door does not close shut on one side Whirlpool ADG789 Dishwasher - Door does not close shut on one side
  • #2 16210956
    kobra2000
    Help: 20
    Rate: 76
    Check the rollers of the upper basket to see if they have broken apart and one is left in the rail at the back.
  • #3 16212707
    lucas13
    Rate: 38
    Nothing is blocking, baskets hide properly. The door does not buckle or open on its own.
  • #4 16213652
    kobra2000
    Help: 20
    Rate: 76
    I suspect that the lines were replaced because they broke. Had the door dropped limply down by any chance. If so, the side of the hinge is bent on the side that do not close. You have to remove and straighten or buy new ones.
  • #5 16214466
    lucas13
    Rate: 38
    I took the dishwasher apart again. I have taken the hinge off, but you can't see it's crooked or worn anywhere. I noticed that the plate on which the hinge is attached is 3 mm too far back in relation to the other side.
    If they were at the same distance, in my opinion it would be ok. Only the metal plate from what I can see is not regulated. There are two screws at the bottom of the torx, but once you unscrew them you can't move it.
    kobra2000
    Help: 20
    Rate: 76
    First try straightening the door swing limiter (gently with a hammer or a key with a longer arm). If it doesn't help, you will have to take the door apart and straighten the metal sheet with the rope attached to it.
  • #7 16221170
    lucas13
    Rate: 38
    You gave me a little thought with this limiter ... He is responsible for how deep the door on a given side closes towards the dishwasher? Which sheet do you mean? about this from this limiter? She looks straight; /
  • #8 16221687
    kobra2000
    Help: 20
    Rate: 76
    The limiter is responsible for ensuring that the door does not fall to the ground when you open it. But when the lines broke, the hinge arm where the line is hooked hit it.
    And the stop is bent, or that arm is bent. You have to straighten the limiter first. And if it doesn't help, as I wrote earlier, you take the door apart and bend your arm. There is no need for a vice and a hammer.
  • #9 17448598
    lucas13
    Rate: 38
    Please close the topic. I got rid of that shit
The discussion revolves around a Whirlpool ADG789 dishwasher with a door that does not close properly on one side, protruding by 1-1.5 cm and allowing steam to escape. The user has already replaced the springs and cables but is unable to find an adjustment mechanism for the hinges. Responses suggest checking the upper basket rollers for damage, inspecting the hinge for bends, and adjusting the door swing limiter. The user discovered that the hinge plate is misaligned by 3 mm, which may be causing the issue. Suggestions include straightening the door swing limiter and potentially taking apart the door to adjust the hinge arm if necessary.
