Peugeot 508 1.6 HDI 2011 - I need a fuel pressure sensor replacement scheme
seebeeck 29802 3
  • #1 17199849
    seebeeck
    Rate: 62
    I want to replace the fuel pressure sensor and there is no access. You probably need to unscrew the EGR. Has anyone maybe a schematic?
    Peugeot 508 1.6 HDI 2011 - I need a fuel pressure sensor replacement scheme Peugeot 508 1.6 HDI 2011 - I need a fuel pressure sensor replacement scheme
  • #2 17199854
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    You need two screws and one tie :)
  • #3 17200156
    seebeeck
    Rate: 62
    will you help and mark which? :)
    Added after 12 [hours] 38 [minutes]:
    maybe better access will be by removing excess tubes from injections?
  • #4 17208910
    seebeeck
    Rate: 62
    EGR I could not pull out completely, I unscrewed it from the screws, the intake outlets without disconnecting the cooling flow, the plate over the injections unscrewed, I pushed it 3-4 cm with and it was enough to get with the key 27. Sensor replaced, the car works. Is the EGR coolant refilled from the radiator surge tank? I got 100ml trying to play with the band.
