Volvo V70 2.4 170 km 2007 - Does not start, turns as if there were no candles
gutek2525 10293 9
  • #1 17201775
    gutek2525
    Hello all.
    I have a problem with my car. After a short route, I returned home, put the car back, everything was ok in the morning I get in I want to start and it turns very lightly as if the candles were unscrewed. Could this be a problem with alternating phases of distribution? I would like to handle something myself because I feel that I will leave a lot of money with the mechanic and it may be some stupidity.
  • #2 17201857
    sk700
    Help: 173
    Rate: 416
    Check the timing first. If you don't know how to pull him to the mechanic, under no circumstances try to start while towing by shifting into gear. The second possibility is that only the starter turns without turning the engine.
  • #3 17201979
    Strumien swiadomosci swia
    Help: 1404
    Rate: 6402
    As long as the throttle does not open, it's cool, when the timing flew, you will leave a lot of money with the mechanic.
    As it is, v70 2007 is the cheapest you can get a full refuel.
  • #4 17202203
    gutek2525
    Unfortunately, it is not possible to tow or launch from the tow, because it is an automatic machine. And when you turn the starter, you spin all the accessories, including the timing belt.
  • #5 17202270
    carrot
    Moderator of Cars
    Help: 1311
    Rate: 3575
    Check the throttle to see if it deviates when the ignition is turned on
  • #6 17202806
    Help: 1404
    Rate: 6402
    Then call the laweteer.
  • #7 17203474
    gutek2525
    It dodges and works. A spinning like no compression
  • #8 17203577
    seat21
    Help: 150
    Rate: 397
    well, write it all when the timing belt was replaced, as a colleague wrote a few posts above
  • #9 17205749
    gutek2525
    It was changed 36k ago
  • #10 17205778
    Dziarski Hank
    Help: 246
    Rate: 930
    Since it spins without compression, it's probably clear that you have a serious failure in the timing system.
✨ The discussion revolves around a 2007 Volvo V70 2.4 that fails to start, exhibiting symptoms of turning over lightly as if there is no compression. Users suggest checking the timing system, as a failure could lead to significant repair costs. The automatic transmission complicates towing or starting the vehicle in gear. The throttle should be inspected for proper operation, and the timing belt's recent replacement (36,000 km ago) is noted, indicating it may not be the immediate issue. The consensus points towards a serious failure in the timing system if the engine spins without compression.
