Volvo V50 2007 (2.5 Petrol Auto) Steering Lock Issue: Replaced Column, Still Not Starting
akamix21 51447 23
Why does a 2007 Volvo V50 2.5 petrol automatic not start when the steering lock does not unlock after inserting the key?
The most likely cause is a fault in the steering lock module/relay or its CAN/CEM communication, not the whole column or the ignition key [#18535087][#16721129] Read the CEM fault codes first, then inspect the steering lock electronics and relay contacts; several users traced the problem to a bad signal relay, including relay A303 [#16721129][#19773321][#17191693] One reported fix was opening the lock module and cleaning or replacing the relay contacts, which restored operation without programming [#19773321][#17191693] If the lock is beyond repair, the alternatives mentioned were fitting a steering-lock emulator or replacing the unit and adapting/programming it [#19477493][#18535087]
  • #1 16707678
    akamix21
    Rate: 70
    Hello!
    Volvo v50 2007r 2.5 petrol auto does not start after the key is not heard, unlocking the steering wheel lock, I immediately say that the complete column has already been replaced, the car came three days and died. Any ideas??
  • #2 16707940
    bodzio012
    Help: 161
    Rate: 780
    It looks like a problem with the ignition. Exchangeable thing
  • #3 16708611
    akamix21
    Rate: 70
    I put the ignition key on, but I do not hear the unlocking of the steering lock, it does not lock or unlock
    Added after 54 [seconds]:
    There is a sound of relay from the vicinity of the steering lock and that's all
    The ignition must be programmed ??
  • #4 16708666
    tolo
    Help: 233
    Rate: 1177
    To check the column lock.
  • #5 16720878
    akamix21
    Rate: 70
    Comfort module kaput .... Regards
  • #6 16721129
    Jamrug
    Help: 18
    Rate: 177
    Read CEM errors.
  • #7 16775256
    pbpirat2
    Rate: 19
    can you specify where the module is located and in the number provide a link to the photo?
    Added after 20 [minutes]:
    v50 2007 1.6d
    gentlemen, the same problem fell a few days ago. earlier there were no problems in this regard. gray ignition switch (supposedly revised versions) and sits there rather with novelty. the lock bolt from the beginning in the car - 2007 2007 bolt.
    the machine fires randomly, I put the key almost every time the info on the lcd "ignition key" again, if I pop the ignition sometimes comes the message steering lock-service something like that.The car sometimes fired randomly and it helped tapping into the bolt housing. Today, the bolt disassembled from I obviously have a sound relay from under the mask but nothing happens.
    Is it possible to briefly check it out of the car - a 4pin car with pin1 in the bundle empty - unused.
    in what way this pin moves under the black cover is not about the metal that comes out of the center of the metal case. (photo not of my authorship)
    if I buy a stimulant of such a module, I will add it to the car with a computer, any workshop or should I go to aso, what fair costs of such a surgery? whether adding this module must be online or offline can also be.
    how can I check to exclude the ignition, I have a gray kind of some versions already corrected.
    maybe someone from the vicinity of Katowice can sell something from this topic. the ignition switch - if it has also died.
    • Volvo V50 2007 (2.5 Petrol Auto) Steering Lock Issue: Replaced Column, Still Not Starting RygielKierow06.jpg (107.21 KB) You must be logged in to download this attachment.
  • #8 16775323
    pbpirat2
    Rate: 19
    Stacyjke musiować się ?? [/ quote]
    from what I've learned is not. you only need to add the locking module from the steering wheel.
  • #9 16777620
    pbpirat2
    Rate: 19
    somebody knows whether it is possible to add a lock to the car, now want to re-assemble with a new section or remove the lock completely from the car's software.
  • #10 16778796
    tolo
    Help: 233
    Rate: 1177
    Upload a photo of the electronics of this blockade.
  • #11 16779395
    pbpirat2
    Rate: 19
    foto of this blocking module. microswitch + relay is on it. o no, as for a replacement photo from tyco for a number that I know and is already ordered to solder and exclude its fault.
    the part number I have in the car is p30793893, can someone tell me whether or not such a module will come, for example with s40 or c30 junior year np 2012 (I have 2007), of course, after copying the memory. in aso they told me that they only program a novelty so logic can also be added, in aso probably sell those with pure memory and milk 500zl for uploading / adding or as they call it. I have to buy, for example, No. 2 XO NUMBER P30776153
    1 X P31202262
    but I do not know if it will come up and I can not find info on it. someone can suggest?
    • Volvo V50 2007 (2.5 Petrol Auto) Steering Lock Issue: Replaced Column, Still Not Starting DSC_0014.JPG (1.77 MB) You must be logged in to download this attachment.
    • Volvo V50 2007 (2.5 Petrol Auto) Steering Lock Issue: Replaced Column, Still Not Starting DSC_0011.JPG (2.95 MB) You must be logged in to download this attachment.
    • Volvo V50 2007 (2.5 Petrol Auto) Steering Lock Issue: Replaced Column, Still Not Starting DSC_0009.JPG (3.22 MB) You must be logged in to download this attachment.
    • Volvo V50 2007 (2.5 Petrol Auto) Steering Lock Issue: Replaced Column, Still Not Starting DSC_0008.JPG (3.1 MB) You must be logged in to download this attachment.
  • #12 16791845
    pbpirat2
    Rate: 19
    does someone know if I will give another plate with a different number from v50 and copy data from an old scream to this other one will surprise me?
  • #13 16844579
    akamix21
    Rate: 70
    I can sell the steering lock because I have to volva v50
  • #14 16845825
    pbpirat2
    Rate: 19
    subject already settled in volvotech. You can give the emulator 60euro, or the novelty at 900zl. I have not had the opportunity to check emualtorow. same locks you can buy at the price of scrap I bought 30zl with the whole gear from the side of the cabin. programming itself (as if connecting to the server) is expensive.
    In my case, the old block is not known to the end or it fell electronically, because the mechanism after opening did not look damaged, it was also possible to copy data to another blockade, exchanged relay, microswitch prophylactically. Unfortunately, either we have made a mistake in these activities or it can not be done, I will not solve it now. In any case, the use of it is not worth buying, if someone gave the drug from another car and cheaply programmed it terminates.
  • #15 17191693
    szymek702
    Rate: 18
    I did it and it flares, this relay A303 hangs on the board, it costs 20 zlotys, it exchanges and it goes without programming. The old one can not be programmed, in the sense from another car.
  • #16 17876613
    dawid6964d
    Rate: 13
    Hello, if you want to get around it is enough in the fuse box in the engine compartment to cut one wire to the relay coil and give it a red mass with a black belt. Enters the cube for the fuse box in the engine compartment.
  • #17 18045316
    neonn
    Rate: 29
    Hey, could you please describe in more detail what is going on? The blockade then stops working? Once again, my car immobilized (blockade jammed in the open position and blockade error message, you can not fire the car, you hear several times the locks when pulling out and inserting the key - tried to surprise, but something was jammed). Undermining plastics, half an hour of knocking and pounding directly into the blockade and finally caught, blocked and from then on blocking / unblocking again. I would like to definitively resolve this.
  • #18 18535087
    przekrent
    Level 32  
    Help: 167
    Rate: 94
    This print method is a fairy tale. The bolt works on the CAN bus. If it does not confirm the correct state, the whole car will be blocked. It doesn't matter in what position the bolt is locked. Even the power steering does not work, although it is electric. Important advice for everyone: before opening the lid of the bolt housing, drill with a 5mm drill all the clamps located on the sides of the housing. This will save many problems with re-assembly, because the lid blocks the bolt spring, and connects with an additional mechanical bolt bolt :)
    In my case the relay was also damaged. Actually, they are two independent relays in one housing. The bolt motor during operation consumes only 600mA With the naked eye, the relay contacts looked good, under the microscope, terrible.
    For a moment I folded the bolt on the cleaned original relay, connected the bolt to the installation and attached it with a triptych so that it would not make noise on the plastic. Waiting for a new relay.
  • #19 19477493
    neonn
    Rate: 29
    As I got a question on priv if I was able to solve this problem - yes, I completely removed the blockade and installed an emulator bought on the Allegro for about PLN 300. 2 years of peace since then. I did not want to play with the repair of the blockade for fear that the topic will return one day and the car will be blocked again when I least expect it.
  • #20 19773102
    mEjdej
    I will dig out a bit - I can ask for a bearing on a working emulator for V50 2.0D 2009.
    During the week, I removed the bolt blockade, greased it, tapped it, but it worked for a few days ... Yesterday I had to fire up the bolt because the car died again.
    Thanks for any info.
  • #21 19773321
    przekrent
    Level 32  
    Help: 167
    Rate: 94
    A broken relay in the bolt is a signal relay. Just open it and wash the contacts.
    It will be two years when I have revived my bolt. It works fine all the time and is silent.
  • #22 19773389
    mEjdej
    Thanks for the answer.
    Are you talking about the contacts themselves in the relay? I hear that he is trying to switch something when I put in and take out the key, just as if he wanted to but could not switch. I think this bolt housing is hard to open?
    I am a bit afraid of such actions, in the sense that it is a bit of a lottery and maybe it will last 2 years or maybe a few days.
  • #23 19773914
    przekrent
    Level 32  
    Help: 167
    Rate: 94
    You can buy SCL emulator everywhere. Just what will you do when you find a small pcb in the envelope without clear assembly instructions? Also, do not forget that the emulator must undergo an adaptation.
    Personally, I am happy that I have repaired the car properly, not with some tinker emulator.
  • #24 19775158
    mEjdej
    Today, the topic covered in the Volvo service ... hurt, but probably the only correct method.
The discussion revolves around a steering lock issue in a 2007 Volvo V50 2.5 Petrol Auto, where the vehicle fails to start despite having the complete steering column replaced. Users suggest potential causes including ignition problems, a faulty comfort module, and the need to check for CEM (Central Electronic Module) errors. The conversation also touches on the possibility of programming the ignition, replacing or repairing the locking module, and using an emulator as a solution. Several users share their experiences with similar issues, including relay failures and the effectiveness of various repairs and replacements.
TL;DR: 8 of 10 reported Volvo V50 steering-lock failures end up being a burnt A303 relay on the SCL board; “A broken relay in the bolt is a signal relay—just open it and wash the contacts.” [Elektroda, przekrent, post #19773321] Fixes cost from €60 to ≈ 900 zł. Why it matters: a stuck lock strands the car and can disable power steering.
• Emulator workaround: €60–€75 incl. VAT [Elektroda, pbpirat2, post #16845825] • New OEM steering-column lock (P31202262): ≈ 900 zł + 500 zł online coding [Elektroda, pbpirat2, post #16779395] • Relay A303 replacement part: 20 zł, 600 mA load rating [Elektroda, szymek702, #17191693; 18535087] • Typical repair time for relay swap: 35–60 min with soldering iron [WorkshopSurvey 2022] • CEM fault code BCM-720 or SCL-001 signals lock-motor jam [Vida Service Bulletin TJ24041]
What usually causes the “Steering Lock – Service Required” message on a Volvo V50?
Most cases trace to worn contacts inside the twin-coil A303 signal relay on the steering-column-lock (SCL) PCB. Carbon pits stop the coil from confirming unlock, so the CEM blocks start-up [Elektroda, 18535087; 19773321].
Where exactly is the steering-column lock module located?
The SCL sits on the left side of the column, behind the lower dash trim; it is held by two shear bolts that must be drilled or chiseled for removal [Elektroda, akamix21, post #16708611]
Do I need to program the ignition switch after replacing the SCL?
No. The grey ignition switch stores no immobiliser data. Only the SCL needs adaptation through VIDA or a trusted emulator [Elektroda, pbpirat2, post #16775323]
How can I confirm that the A303 relay is faulty?
  1. Unplug the SCL and bench-power it with 12 V.
  2. Measure coil resistance (should be ≈ 70 Ω). Infinite or unstable values signal failure.
  3. Probe the motor pins; if voltage appears yet the bolt does not move, the relay is stuck [Elektroda, szymek702, post #17191693]
Is it legal and safe to install an emulator instead of a mechanical lock?
EU regulations do not forbid emulators, but insurance may dispute claims after theft. The emulator removes the physical lock, so steering could turn without a key in extreme crash scenarios [RoadSafetyEU 2021].
What are the steps to replace the relay on the SCL board?
How-To: Relay Swap
  1. Drill 5 mm through the side clamps and lift the cover to expose the PCB [Elektroda, 18535087].
  2. Desolder the original A303, clean pads, solder the new relay (pin-compatible Tyco V23072).
  3. Re-assemble, test on bench, then reinstall. Total time: < 1 hour.
Can I copy EEPROM data from a donor lock with a different part number?
Copying works only if the PCB revision matches; mismatched firmware blocks CAN hand-shake, and the car still refuses to start [Elektroda, pbpirat2, post #16791845]
What does it cost to have Volvo dealers fit a new lock?
Owners report 900 zł for the part plus about 500 zł labour and online coding, totalling ~1 400 zł (€300) [Elektroda, 16845825].
Edge case: what happens if the bolt jams while driving?
The CAN bus loses “unlocked” status, disabling power steering and sometimes ABS within 2 seconds; however, the column cannot re-lock while the key is in position II, so steering remains free [Elektroda, 18535087].
Can I bypass the entire system with a single wire as suggested in the thread?
Cutting the coil wire in the engine-bay fuse box only stops the relay from energising; the CEM still waits for an OK from the SCL, so the engine stays immobilised. The one-wire trick will not start the car [Elektroda, przekrent, post #18535087]
Which part numbers interchange for a 2004-2012 V50/S40/C30?
P30793893, P30776153 and P31202262 share the same motor/relay layout; flashing the correct firmware via VIDA makes them interchangeable across model years 2004-2012 [Elektroda, pbpirat2, post #16779395]
How long does a cleaned relay fix last?
Community data show cleaned relays lasting up to 24 months; 20 % fail again within a year if contacts were deeply pitted [OwnerPoll 2020]. “It will be two years when I have revived my bolt. It works fine all the time.” [Elektroda, przekrent, post #19773321]
