Deep Well Disinfection: Sodium Hypochlorite Use, Post-Winter Water Smell & Annual Procedure
sylwek19l 7479 6
  • #1 17204616
    sylwek19l
    Hello everyone, I would like to ask how to disinfect the water after winter, the smell of sludge after 3 hours of pumping smells hardly noticeable, but I should carry out this procedure at least once a year. I can't find on the net how to do this and how much to add sodium hypochlorite and what to do next. Well from 2017, 125mm water surface at 14m and 32m deep.
    I am asking for help from professionals or people who have had experience in this matter, thank you in advance
    Well disinfection by pressure dosing and flushing
    #2 17204669
    ladamaniac
    Help: 724
    Rate: 2081
    I am a theoretician, and I finished water technology about 20 years ago, but what I remember is that there is a problem with drills at home. Generally they are cleaned by intensive pumping. As for disinfection, the solution would be suitable to be administered under pressure. At home, you pour a disinfecting solution (mainly sodium hypochlorite, although there are now some preparations based on hydrogen peroxide and silver ions, probably such a fashion) prepared according to the instructions and turn on the taps, etc., until you smell chlorine, then turn off. Then a 24h break and intensive rinsing. It is appropriate to make the microbiological purity of water in the Sanepid or other laboratory to make sure that the treatment does not need to be repeated.
  • #3 17204729
    sylwek19l
    I will probably use sodium hypochlorite, so when I pour it into the well, I unscrew all the collection points until I feel chlorine and turn off, and the next day I do a few hours of pumping with all the outlets at the same time - this is what I understood, please confirm, a good tip also for other people who have wells.
  • #4 17204992
    Covul
    Help: 29
    Rate: 49
    You understood well, buddy. If anything, you can get hypochlorite in "Chemia" on Cobowa Street, they sell by kilograms, if you take your container it will be cheaper.
  • #5 17205806
    ladamaniac
    Help: 724
    Rate: 2081
    Exactly right, check the water in some lab. There can be several reasons for this smell of mud. By the way, when you have little children, check nitrates.
  • #6 17206853
    DJ MHz
    Help: 40
    Rate: 255
    Do you have any filters?
  • #7 17207291
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1009
    Chloramine is used to disinfect water in deep wells, a bucket is poured into the well and after three days it is pumped out.
To disinfect a deep well after winter, sodium hypochlorite is commonly used. The procedure involves adding the disinfectant solution under pressure, then running taps until a chlorine smell is detected. After a 24-hour period, intensive pumping should be conducted to flush the system. It's recommended to test the water for microbiological purity at a laboratory to ensure the disinfection was effective. Other potential solutions mentioned include chloramine and alternative disinfectants based on hydrogen peroxide and silver ions. Users are advised to check for additional issues such as nitrates, especially if there are children in the household.
