Title: Achieving Lower Ping on LTE for PC Gaming: Router, SIM, Antenna, and Band Aggregation
Emkai 8814 2
  • Can LTE router and antenna reduce ping below 20 ms
    #1 17205747
    Emkai
    Hello, playing on the PC I use the internet from a phone connected with a USB cable. This is LTE play, the ping I have in speedtte is 33 ms, the phone supports the 800mhz band. Bts to which the connection is a few meters from my house is unloaded, there are only single-family houses in the area. I found information that it is Play's own mast, LTE bands 800.1800, 2100 (probably 2,600 too). My question is, is the router + SIM + antenna + aggregation still able to lower the ping? For example, below 20 ms, it won't work, because it can't be better on LTE. Thanks in advance for the information, best regards
  • #2 17205773
    myszkoscielna
    Help: 62
    Rate: 31
    Use winmtr.exe to the host you are pinging, what are the results.
    As the slowdown is for BTS, nothing aggregation / ant will do anything.
