Connecting and Configuring Versa 15 Control Panels with GPRS-A Module for Remote Alarm Notification
jaworski11 6453 18
How do I correctly connect and configure a Versa 15 control panel with a GPRS-A module to get alarm SMS notifications and remote arming/disarming?
Program the Versa outputs for the events you want to report (for example burglary, tamper, technical), connect those outputs to appropriately configured GPRS-A inputs, and for remote control connect the GPRS-A outputs to suitably programmed control-panel zones with authorized phone numbers and messages entered [#17218704] You do not need to connect control-panel outputs to module inputs unless you specifically want the module to react to those signals; the manuals also mention the basic line connection (ring/tip) and AC control wiring [#17216096][#17218489] If arming works but disarming does not, the GPRS-A output is probably configured bistably, while the VERSA arming/disarming input works monostably, so use one SMS command such as “turn on output 1 for time” instead of separate enable/disable commands [#17284113] The thread also notes that multiple control SMS commands and multiple panel responses can be configured, so the system can be made to work in the intended way [#17285865]
  • #1 17215662
    jaworski11
    I have Versa 15 control panels and a GPRS-A module.
    I would like to use this module to be notified of possible alarms and be able to remotely control it.
    I am asking for help in correct connection and configuration of the module and the control panel.
    Thank you very much in advance for your help.
  • Connect ring and tip plus AC control to GPRS-A
    #2 17216096
    mikan4
    Help: 85
    Rate: 76
    you connect ring and tip (you have it on the control panel board in the module), or you program the outputs in vice and the inputs in GPRS :) Do not forget to connect the ac control, it is useful when the electricity is no longer available (then scratching the contents of the refrigerator to someone for storage). You have everything in the manual (attached in paper to both the control panel and the module).
  • #3 17216702
    bhtom
    Help: 446
    Rate: 604
    jaworski11 wrote:
    I am asking for help and if anyone wants to help ...
    To help does not mean to do everything for you ...
    Write what you have done in the topic so far and what is your problem?
    Best regards.
  • #4 17217553
    jaworski11
    I did this: I connected the OUT3 output to the first input of the gprs module. OUT3 of the control panel as a burglary alarm., Control panel input Z4 (disarming / arming) as no I connected with the input z1 on control panel
  • #5 17217831
    mikan4
    Help: 85
    Rate: 76
    jaworski11 wrote:
    I connected the control panel input Z4 (disarming / arming) as no to the control panel z1 input
    China does not understand this. What for, what and why ?? What did the "artist" mean ?? What function is this supposed to have? Entry with entry or exit of the control panel ??
  • #6 17218276
    suworow
    Help: 650
    Rate: 1278
    I deleted the unnecessary statements.
    However, please bear in mind two things:
    Yes, help is provided on the forum, but people who are trying to give something of themselves and not waiting for a ready. See section rules: https://www.elektroda.pl/rtvforum/topic3077742.html
    We try to be respectful to our interlocutors, even when we may not fully agree with them.
    I leave the topic, but I expect my colleague to describe once again all the connections made, the settings on the side of both devices, what functionality he wants to get, and of course he will remain calm ;)
    best regards
  • #7 17218479
    jaworski11
    Sorry for the confusion ... One more time then. Versa OUT3 output set as "burglar alarm" and connected to Input I1 of GPS module.
    Versa Z4 input set as NO and as "system arm / disarm" and was connected to the O1 output of GSM module.
    Is this connection properly made?
    In the event of a violation of the inputs and triggering an alarm, I would like to receive, for example, an SMS from the module about such an event. Additionally, I would like to be able to arm / disarm the alarm via SMS or GX control.
    Thanks in advance for the info.
    best regards
  • #8 17218489
    bhtom
    Help: 446
    Rate: 604
    You had to write what you want to get the functionality of the module in combination with Versa ...
    You do not need to connect the control panel outputs to the module inputs.
    Did you read and understand the control panel and module instructions?
    Best regards.
  • #9 17218670
    jaworski11
    As I wrote: the functionality is to be obtained in such a way that when the inputs are violated and the alarm / siren is triggered, the information is sent to the module which will immediately notify me about it. I will be able to disarm this alarm remotely.
    Regarding the second question: this is how I read this manual of both the module and the control panel.
    Thank you in advance for possible clarification if something is wrong.
  • #10 17218704
  • #11 17218728
    jaworski11
    @sharp thanks for the hints
    I think so now and do not insist on my solution. The module can be treated as a monitoring converter but it is important that I can remotely control the alarm. If possible, approx.
    I am an amateur in this topic. I set an alarm a few years ago and it works without any problems to this day. Now I have bought the module because of this remote control ... and as you can see the stairs have started, so please be understanding if you think that I am writing stupidity
    Added after 4 [hours] 1 [minutes]:
    With this connection, as I mentioned earlier, I can only arm the alarm via CLIP or SMS. Unfortunately, it doesn't work the other way, i.e. I can't turn it off.
    Will you suggest how to improve it?
    Thanks in advance
  • #12 17283928
    jaworski11
    Subject to be closed.
  • #13 17284113
    dariusz.bembenek
    Stationary Alarms specialist
    Help: 455
    Rate: 615
    Has your friend already dealt with the problem?
    Probably a colleague controls one module output in a bistable way, i.e. he has two text messages: on and off. But...
    On / off input in the VERSA control panel, it works only in a monostable manner, so only one control SMS should be configured, which should be entered in the position: "Turn on output 1 for time". A colleague has probably set SMSs in the following columns: Enable output 1 and Disable output 1.
    It won't work like that.
  • #14 17285865
    jaworski11
    I dealt with the topic myself ... Unfortunately, no one here on the forum was kind enough to help me. I don't know if it's out of ignorance or reluctance, but it's not that important anymore.
    Now everything works as I wanted. I will just add that there are several control SMSes and there are also several answers from the control panel.
  • #15 17286103
    dariusz.bembenek
    Help: 455
    Rate: 615
    We apologize to my colleague for not encouraging enough self-diagnosis. In the end, it ended well, because my friend handled it on his own. And this is a plus for my friend, because at least the subject seems understandable.
    Of course, such a configuration is possible. Nobody denied it here. The point is that a colleague during the discussion presented a variant with control from one text message and it did not work, so there was advice in this matter.
    Let's just hope that the system has been properly configured (just receiving SMSs and controlling the standby from the phone does not mean that this system cannot be bypassed with a stick).
  • #16 17591073
    adamekzzz
    I was interested in the problem because I bought GPRS-A for Versa 10, and I have a similar problem and in my opinion it is not a matter of laziness because I also read both instructions and I am also an amateur. On the other hand, the level of the experts' responses irritated me, I feel sorry for the founder of the topic because I know what it is like, because I had similar problems recently, in addition, I couldn't call Satellite because it was Saturday and I returned with the 200 km module back. Leaving aside,
    I will be glad to know what the above comment means, because maybe I can also get around the Satellite alarm system with a "stick", which for obvious reasons I would prefer to avoid, I will add that I programmed the control panel after reading the manual.
  • #17 17591109
    dariusz.bembenek
    Help: 455
    Rate: 615
    I do not know what my colleague was irritated by, because many people gave specific advice on this thread. Anyone can install alarms, be it beginners, installers with considerable experience, etc. However, you should keep in mind that these installations are dedicated to "qualified" people - however this concept is understood by us. I understand that these installations are often installed by people who are not involved in the topic. However, that doesn't mean it's the right approach. These are systems designed to provide a sense of security, and people who are unfamiliar with these installations may perform them contrary to art - and as a consequence the system may not meet their expectations.
    How to prevent it?
    I have the impression that it is impossible to write a "recipe" for a well-made installation. But there are certainly many factors at play (including the basics of electrics, electronics, knowledge of the functioning of individual alarm elements, etc.).
    The manual does not describe how to program the control panels, but only deals with issues related to individual options. It is now up to the installer to choose which functions of the control panel to choose based on the threat analysis etc.
    As for the stick - it's a metaphor. The point is that many people who install alarms (but without knowing them) often consider the final moment when "motion in front of the detector turns on the howler". But this is only the first step. Important are also matters such as password policy, the legitimacy of using keyfobs and the resulting risks, proper programming of the GSM notification (informing, among others, about the loss of the primary power supply), appropriate connection and programming of the tamper circuits, reduction of the number of delayed inputs to the necessary minimum installation and selection of detectors and much more.
    I am not saying that you cannot install the alarm yourself well - it is possible. However, when deciding to take such a step, you should carefully understand the topic - if the system is to be decent.
    What's the trouble? What won't work? I think it is worth setting up a separate thread.
  • #18 17593121
    suworow
    Help: 650
    Rate: 1278
    I do not know what my friend was irritated with,
    And I understand the irritation of my colleague @adamekzzz
    He reaches for the last resort, finds an interesting topic on the forum and what? He does not find an understandable and specific answer for him.
    The only question is whether he directs his attention in the right direction. As colleague Darek wrote, an attempt was made to help, because the author got a second chance, although if he adhered to the regulations, the topic should have ended up in the basket long ago.
    In my opinion, there was simply no description of the solution.
    The author of the topic found the time and willingness to express his regrets, but he did not think about writing how he dealt with this topic. After all, not for us, not for colleagues @sharp or @ dariusz.bembenek who do not need such advice, but just for such users as a friend (adamekzzz) and many others who may not fully understand what NO is, NC COM, monostable, bistable, what role do inputs and outputs play, etc. For those who need to write everything from scratch, which may not always be obvious to specialists,
    The forum does not have to (should) be a place where only specialists give advice. As a moderator, I am most happy when those who recently came here for help, start to provide it themselves ... In my opinion, this is the forum, in my opinion, this is its idea.
    Like my friend, I am waiting ....
  • #19 17758936
    rafdyd
    Rate: 16
    The second time around, I don't think you should get a single answer. I understand that you coped with it, but this is probably why you asked on the forum how to connect, so that in the future, someone reading your thread could read the topic and connect it at home. Unfortunately, like a kid from kindergarten, you took offense at everyone and did not deign to state how you connected it. Oki. It's hanging for me, but I will write down your nickname in order to ignore your thread in the future and not even help with a word.
The discussion revolves around connecting and configuring the Versa 15 control panel with the GPRS-A module for remote alarm notifications. The user seeks assistance in establishing the correct connections and settings to enable alarm notifications via SMS and remote control of the alarm system. Various responses provide insights into wiring configurations, programming outputs and inputs, and the importance of understanding the functionalities of both devices. Key points include connecting the OUT3 output of the control panel to the GPRS module's input for burglary alarms and setting up the Z4 input for system arming/disarming. Some participants emphasize the need for clarity in the desired functionalities and the importance of following the manuals for both devices. Ultimately, the user successfully resolves the issue independently, achieving the desired remote control capabilities.
TL;DR: Use one monostable SMS to pulse Versa arm/disarm—"works only in a monostable manner"—and prefer TIP/RING for zone‑level alerts. Map panel outputs to module inputs only if you need generic alarms. This guide covers wiring, SMS/CLIP control, and power‑loss alerts for Versa 15 + GPRS‑A. [Elektroda, dariusz.bembenek, post #17284113]
Why it matters: It prevents disarm failures and ensures precise alerts while keeping remote control reliable for DIY and pro installers.
How should I connect Versa 15 to GPRS‑A for detailed, per‑zone SMS alerts?
Use the panel’s dialer outputs TIP and RING into the GPRS‑A’s TIP/RING. Program the panel communicator and let the module translate events to SMS. This provides zone‑level notifications rather than one generic ALARM. As one expert put it, "You would get specific information WHICH zone triggered WHICH alarm." This avoids consuming multiple outputs for basic signaling and improves diagnostics. [Elektroda, Anonymous, post #17218704]
Is wiring OUT3→I1 and O1→Z4 correct for SMS and remote control?
It works for a basic ALARM notification and arming. For clean disarming, configure the Versa zone as System arm/disarm (NO) and make the module output monostable. In the module, assign the control to "Turn on output for time" so the panel receives a short pulse. Avoid using separate ON and OFF commands on the same output because the panel’s input expects a momentary action. [Elektroda, dariusz.bembenek, post #17284113]
Why can I arm via SMS/CLIP but not disarm?
Your module output is likely set as bistable (ON/OFF). Versa’s on/off input expects a monostable pulse. Change the module command to "Turn on output for time" and wire it to the configured arm/disarm zone. As the expert noted, "It won’t work like that" when using latched ON/OFF for this input. Test both arming and disarming after the change. [Elektroda, dariusz.bembenek, post #17284113]
How do I program multiple alarms (burglary, tamper, technical) to different SMS notifications?
Program dedicated control panel outputs for each event type (e.g., Burglary, Tamper, Technical). Wire those outputs to separate GPRS‑A inputs. In the module, set each input type and message text, and adjust timing and electrical parameters to match the panel outputs. This way, each event triggers a distinct SMS, improving clarity and response. [Elektroda, Anonymous, post #17218704]
What do TIP and RING actually do in this setup?
They emulate a telephone line between the panel and the module. The panel reports events over TIP/RING, and the module converts them into detailed notifications. This method preserves outputs for other uses and gives you precise event context, instead of a single generic alarm signal. It’s the recommended approach for granular insight. [Elektroda, Anonymous, post #17218704]
How do I configure CLIP and SMS control safely?
Assign module outputs to respond to commands only from authorized phone numbers. Map those outputs to control zones or inputs in the panel. Define clear messages and confirmations for each action. Avoid exposing remote disarm widely; limit who can trigger it and log every command. The expert advised setting numbers, messages, and outputs deliberately. [Elektroda, Anonymous, post #17218704]
How-To: set monostable arming/disarming over SMS?
  1. In Versa, set a zone (e.g., Z4) as System arm/disarm, NO.
  2. Wire a GPRS‑A output (e.g., O1) to that zone.
  3. In GPRS‑A, map an SMS/CLIP command to "Turn on output for time" to send a short pulse. [Elektroda, dariusz.bembenek, post #17284113]
Can I use several SMS commands and get multiple responses?
Yes. You can define several control SMS commands in the module and receive several distinct replies from the system. Users have reported operating multiple actions this way once wiring and command mapping were correct. This supports flexible remote control while keeping feedback clear. [Elektroda, jaworski11, post #17285865]
How do I get notified about power failures and recovery?
Wire and supervise the AC input so the module can send an alert when mains fails and when it returns. This helps you act before batteries drain. As one installer emphasized, "Do not forget to connect the ac control." It’s essential for reliability during outages and protects appliances and security. [Elektroda, mikan4, post #17216096]
What I/O does GPRS‑A provide for wiring options?
Typical GPRS‑A modules expose 8 inputs and 4 open‑collector outputs. That supports multiple event lines from the panel and several remote control functions. Check the manual for exact electrical ratings and any model revisions. Use available I/O to separate burglary, tamper, technical, and power events cleanly. ["Satel GPRS-A Manual"]
What security pitfalls should I avoid when enabling remote disarm?
Use strong codes, review password policy, and limit delayed entry zones. Wire and program all tamper circuits. Enable GSM notifications for primary power loss. Restrict remote disarm to trusted numbers and log actions. As noted, "These are systems designed to provide a sense of security," so configure them accordingly. [Elektroda, dariusz.bembenek, post #17591109]
My notifications say only "ALARM." How do I get specifics?
Output‑to‑input wiring gives only generic ALARM status. Switch to the TIP/RING monitoring method to receive specific event and zone details. The expert warned that with simple output bridging, "you take several outputs and only have general information: ALARM." Rewire and reprogram for detailed context. [Elektroda, Anonymous, post #17218704]
