[Solved] Asus ROG i5-7th Gen Windows 10 - Driver Power State Failure Error: Tips & Troubleshooting Guide
Janateuszp 63234 10
How can I fix a Driver Power State Failure BSOD on an Asus ROG i5 7th gen laptop when Windows 10 will not boot after a clean install?
The problem was caused by a faulty built-in battery; replacing the 7-month-old battery and then installing clean Windows fixed the Driver Power State Failure issue [#17245247]
  • Clean Windows 10 reinstall still triggers driver power state failure
    #1 17217427
    Janateuszp
    I warmly welcome. There was a problem with today's normal laptop switching. A repair window popped up, even before entering windows 10. I restored the system to the state it was in before the update, in which an error popped up. The restoration was not good, so I returned to the initial state.
    Failed to. I downloaded a picture of my windows from another laptop and joined the installation from the pendriva of the new windows 10 system. Partition cleaned and the installation finished. After rebooting the laptop shows the error as in the subject and at this stage I stood still. I do not have to remove this error from the control panel (and only such guides I have seen and tried), because I do not have the possibility to load windows fully, and with it I do not have that possibility. Has someone met with something similar?
    Asus rog i5. 7 generations, 8 gb frames.
    Regards and thanks for help
  • #2 17217894
    KSRhaziel
    Level 36  
    Help: 271
    Rate: 275
    Where did you get the Windows image from?
  • #3 17218019
    Janateuszp
    The image was downloaded from the microsoft site. Over the night I tried to download a new image and install the system on another flash drive. The error is the same. In the bios, no hardware problem can be seen
  • #5 17218115
    Janateuszp
    I stand at a similar level as the person in that topic, only I can not even come to privacy settings. Driver power pops up before I have the opportunity. I have access to the command line, but I also have not found a reasonable exit from this place. Anyway, service. I will look for someone competent in my town tomorrow. Until then, I have not closed the topic yet and are waiting for my time
  • #6 17218119
    DriverMSG
    Help: 3984
    Rate: 4882
    What exactly version?
  • #8 17218268
    DriverMSG
    Help: 3984
    Rate: 4882
    I still do not know what exactly you downloaded, so check with another system compilation.
  • #9 17218742
    Janateuszp
    The possibility of downloading from the microsoft site was just one option called Windows 10. I suspect that the latest version was available for download, which was available from April 30, that is 1803. Where can I get the earlier versions?
  • #11 17245247
    Janateuszp
    The problem is described in detail and the laptop sent for warranty, which I wanted to avoid. However, it was not so bad with time, because I got a laptop today. The problem was solved by replacing the battery and just uploading clean windows. A defective 7-month, built-in battery made a problem. Greetings and thanks for help :)
The discussion revolves around a "Driver Power State Failure" error encountered on an Asus ROG laptop with an Intel i5 7th Gen processor running Windows 10. The user attempted to restore the system to a previous state and later performed a clean installation of Windows 10 from a USB drive, but the error persisted before fully booting into the OS. Various responses included inquiries about the source of the Windows image, suggestions to check the version of Windows, and links to external resources for troubleshooting. Ultimately, the issue was resolved by replacing a defective battery and reinstalling a clean version of Windows, after which the laptop functioned normally.
