- After upgrading to 1803, the computer is not visible in the home network.
krycha_g 11880 7
  • #1 17229481
    krycha_g
    After upgrading to 1803, the computer is not visible in the home network. It can not see other computers. Home group deleted, so how to share files and folders
    clubs
    Help: 629
    Rate: 406
    In the services find "Publication of the function discovery resources" and see if the startup mode is automatic (how not to change it) and restart
  • #3 17229589
    krycha_g
    It helped. Thanks, thanks, thanks.
  • #4 17455699
    oldNW
    The service works - automatic start, but it did not help. A computer invisible on the web and can not see others.
  • #5 17467978
    skorakora
    Rate: 25
    In my case it helped
    I do not see the home server but that's probably because it has sharing turned off
    But I see myself and not before
    PS: write it only so that in the future you can return to this thread
  • #6 17944381
    ggrzg
    It helped immediately, but you have to switch to automatic mode, and if you had an automatic mode, look for the reason for the visibility barrier in the network
  • #7 18049941
    Drzonek
    Good morning,
    thanks to your portal I managed to set up a network for several computers and I was already charmed with "greetings with a goose", that everything haunted me as I wanted, and suddenly it turned out in a surprising way that it is not and I can not fight it.
    - all PCs are on Win 10 PRO / 64 bit
    - all have fresh systems and an identical anti-virus with the same level of protection
    - they are all after the same recent updates
    - they're all in a private network
    - all network discovery is marked
    - all files and print sharing are checked
    - they are all OFF for password protected sharing
    - all of them are marked in the services "Publication of the function discovery resources": automatic start-up mode - this NORMAL, not with the description "delayed start"
    - and unfortunately some comps (there are no rules that) see only like in spite of the "automatic run mode" in the PUBLICATION OF RESOURCES FOR FINDING FUNCTIONS - I click on the function "Restart service" assigned for this service.
    Then in a second everything is OK, but after restarting the comps, there is chaos again - some see and others do not.
    I have even added a shortcut of SERVICES to the taskbar, because I have to use this application so often.
    I am counting on your help, because I have already given up myself.
  • #8 18522707
    neuronedi
    Has anyone managed to resolve this sharing instability in Win10?
    I test your advice and with 3 computers only one can see all, and the rest only see the first one. They do not see themselves.
    PC1 win 10 pro: Network -> PC1 PC2 PC3
    PC2 win 10 pro: Network -> PC1
    PC3 win 10 bass: Network -> PC1
    Regards
    Thomas
After upgrading to Windows 10 version 1803, users reported issues with their computers not being visible on the home network and being unable to see other devices. Solutions discussed include ensuring that the "Publication of the function discovery resources" service is set to automatic and restarted. Some users confirmed that this adjustment resolved their visibility issues, while others continued to experience problems despite following the same steps. Additional troubleshooting steps included checking network discovery settings, ensuring all devices are on a private network, and disabling password-protected sharing. Users noted inconsistencies in visibility among multiple computers running Windows 10 Pro and Home editions.
