Isomatic Hormann Gate and Liftronic 500 Drive: Issues with Rail Curving During Closing
milik122 7890 4
  • #1 17233420
    milik122
    Hello, it is about the Isomatic gate and the liftronic 500 drive. Well, I installed the gate step by step according to the instructions. However, when closing, the drive rail curves upward when the second section is lowered. I've been in the head for two days now but I can't deal with this problem which can cause these complications. I connected the rail with a fastener, but only one side entered the grooves, the other was not because it is too long. In the middle I additionally connected with a clamp. The tape is tight but the hand is very hard to move. I am asking for help, I bought and set up a gate for a disabled person to make their life easier, but I can't finish my work. Thank you for the advice and best regards
  • #2 17235291
    Marek J.
    Help: 526
    Rate: 948
    You have not done something correctly, you have "overdone" something else. For this reason, the stroller may jam in something ...
    Does the disengaged door move slightly in both directions? Attach photos, video from work. It will be easier to diagnose ...
  • #3 19656343
    malczak650
    Rate: 9
    I know, buddy, that a lot of time has passed, but have you solved the problem with this drive because for me it is the same as you described?
  • #4 21698540
    maiejczub
    Has anyone solved this problem?
  • #5 21731088
    cholmabarbara
    >>21698540
    Hello, in our case it turned out that the rail connector was inserted incorrectly. I.e. inserted first into the wrong rail. Only one of the rails allows the coupler to sit deep. We then joined the two rails together and only slid the coupler until it clicked into place.
