Fix ASUS X541U Windows 10 Error Code 0xc000000e after External WiFi Card Installation
ojciec10 8457 2
  • #1 17237634
    ojciec10
    Rate: 113
    I have a problem running Windows 10 on an ASUS X541U computer. The computer worked properly until an external wifi card was installed. The card itself was working properly but after restarting the system a message with error code 0xc000000e popped up. I created a usb drive with windows 10. I tried all the repair options from the windows 10 installation disk. I also tried the program from these pages:
    https://www.easeus.com/backup-utility/a-requi...e-is-not-connected-or-cannot-be-accessed.html
    running the pendrive with the above program installed results in error code 0xc000000d.
    I also tried booting in safe mode - the same problem every time
    Windows 10 64bit
    How can you run windows?
  • #2 17237680
    CodeBoy
    Help: 138
    Rate: 693
    I understand that you deleted the card? And there is still the same problem?
    I bet on physical damage, try booting from some live linux and see if it works. It is possible that something has damaged in the notebook itself. Ew. may need cleaning.
