Samsung CLX 6260FW Scanner Not Detected After Windows 10 Update: Possible Fixes?
killer6969 6924 7
  • #1 17240048
    killer6969
    Hello everyone,
    I have been using the Samsung CLX 6260FW multifunction device for a year, so far everything worked without any complaints, but after yesterday's update of windows 10, the scanner stopped working.
    All other functions work, printing and photocopying normally, but the scanner suddenly failed.
    Tried changing the cable, removed drivers and easy printer manager, reinstalled the latest versions.
    Nothing helps, when I try to scan I get the message: "Scanning application supported by easy printer manager has not been installed. Please install scanning application".
    I also tried to install other drivers and applications for Samsung, I also tried on another computer - to no avail.
    Has anyone had a similar problem or can advise how to restart the scanner?
    Thank you in advance!
  • #2 17242997
    ERESJOT
    Help: 63
    Rate: 21
    On what system was the scanner working properly?
  • #3 17244954
    renaya1101
    My Samsung CLX 3305 printer - after installing the latest winodows 10 update, it also stopped scanning. "Not available" on the display. The lamp does not move when the printer is turned on. it shines red, green, blue - briefly and goes out. it stops. I do not know what to do. I installed new drivers, nothing ...
  • #4 17261539
    bundy81
    Rate: 20
    Also I can't scan in 3305FW no scanner or i / o error
  • #5 17274273
    killer6969
    The printer works all the time on Windows 10 - after updating the system, except for the scanner, everything works as before
  • #6 17277673
    bundy81
    Rate: 20
    Install this patch. Link
    Answer found on the HP forum Link
    Just download and install, everything is back to normal.
    best regards
  • #7 17282082
    killer6969
    best regards
    Thank you very much! The patch solved the problem! The scanner works fine!
  • #8 17974200
    L_I_L_A
    You helped me too, thanks! : *
The Samsung CLX 6260FW multifunction device experienced scanner functionality issues following a Windows 10 update, while other functions like printing and photocopying remained operational. Users reported similar problems with other Samsung models, such as the CLX 3305, where the scanner was not detected or displayed errors. Suggested solutions included reinstalling drivers and applications, but the most effective fix was installing a specific patch found on an HP forum, which resolved the scanning issue for multiple users.
