Redmi 5 Plus Hotspot Issue: No Internet Access on Connected Device & MIUI 10 Update Impact
Helmowy 3615 2
  • #1 17662027
    Helmowy
    Hello, I have a redmi 5 plus and for some time (it could have been happening for a long time but I have not noticed) but when I share the internet via a hot spot, the message no internet access pops up on the other device, then in the network settings I have to change the preferred network to 3G, of course with LTE, then the internet works on the device connected to the hot spot but then there is no internet on redmi ingl, then it comes out so that only one device can use the internet because on the other it is cut off, does someone have such a problem and maybe know how fix because earlier, probably from the moment of updating to miui 10, something happened, as I said before, everything worked without problems, I could share the internet and use it at the same time
  • #2 17662089
    xury
    Automation specialist
    Help: 878
    Rate: 1497
    In short, I am in Redmi 6 after the miui update, sometimes I also have it. It helps to disable and enable wifi.
