Skoda Octavia 1.9 TDi 110 HP - How to remove the door handle from the rear door.
slaw777 12291 4
  • #1 17042313
    slaw777
    Rate: 215
    Hello all.
    How to remove the door handle completely from the rear left side? I unscrewed the T20 Torx on the side of the door until the metal element came out, which comes out, I would add that I did not unscrew the Torx 20 completely.
    Thanks in advance for reply.
  • #2 17042992
    RafalGT2
    Help: 77
    Rate: 223
    When you remove this meal element, you detach the door handle line, then the whole handle is firmly shifted backwards and should come out
  • #3 17043168
    slaw777
    Rate: 215
    Nice thanks check it out.
  • #4 17351797
    slaw777
    Rate: 215
    I do just that, but the handle does not slide back, even after a hard pull.
  • #5 17415987
    slaw777
    Rate: 215
    I have already assembled the door handle, it sticks out a bit from the door, but it does not bother so much, I will only add that pulling the handle back strongly did not want to go out, maybe I haven't unscrewed something else yet?
