[Solved] Creating a GSM Faraday Cage for Child's Room: Blocking Signals, Window Solutions & More!
pdusp 16302 30
How can I block GSM and Wi‑Fi signals in a child’s room, including the window and balcony, without using an illegal jammer?
A room-wide Faraday cage is not a practical solution here; to block GSM/Wi‑Fi you would have to cover the walls, floor, ceiling, windows and doors with conductive mesh, otherwise signals will leak in [#17244750] A jammer is a bad idea because a good one costs about PLN 4,000, has to jam many bands, may affect the household, can stop emergency calls, and is illegal [#17244771][#17244909] The simplest legal answer from the thread is to take the phone away at set times, for example at night, and return it in the morning [#17244750][#17244792] Other practical options are Wi‑Fi schedules on the router and parental-control apps such as ESET Parental Control, Norton Family Premier, Phone Sherif, or KidsLox [#17244789][#17245770][#17245091] Another suggestion was to replace the smartphone with an older basic handset without Wi‑Fi, or at least one with only very limited data capability [#17245973]
  • #31 18280894
    pdusp
    Rate: 15
    If such a cage is to protect bedrooms in a block of flats, the mesh of the copper mesh must be below 0.5mm, this is due to the wavelength so that the wave from the 5G transmitter / frequency up to 80GHz / does not penetrate.
    We will pay PLN 230 for 1m2 on alledrogo
    COPPER MESH
    thickness: 0.3 mm
    mesh: 0.5 x 0.5 mm
    width: 1000 mm
    The BUY NOW price is for 1 meter of mesh
The discussion revolves around the feasibility of creating a GSM Faraday cage in a child's room to block signals, particularly GSM and Wi-Fi. The original poster considers using a copper mesh grounded under plaster but seeks advice on how to address windows and balconies. Various responses suggest alternatives to a Faraday cage, such as setting specific phone usage times, using parental control apps, and employing simple jammers. Concerns are raised about the legality and health implications of jammers, as well as the psychological effects of restricting a child's access to technology. Suggestions include using older phones without internet access, implementing Wi-Fi schedules on routers, and engaging children in non-digital activities to reduce screen time.
TL;DR: 0.5 mm copper mesh costs PLN 230 per m² and blocks signals up to 80 GHz [Elektroda, pdusp, post #18280894] "The easiest solution is to pick up the phone" [Elektroda, icosie, post #17244750] U.S. penalties for illegal jammers reach $112,500 per act [FCC, 2023].
Why it matters: parents often seek safer, lawful ways to curb late-night smartphone use without harming health or neighbours.
• Copper mesh ≤0.5 mm openings gives ≈80 dB attenuation at 3 GHz [IEEE, 2021] • Price: PLN 230/m² for 0.5 × 0.5 mm, 0.3 mm thick sheet [Elektroda, pdusp, post #18280894] • Multi-band commercial jammer ≈PLN 4,000 [Elektroda, icosie, post #17244771] • Poland bans private RF jammers; UKE may fine up to PLN 1 million [UKE, 2023] • Typical smartphone supports 14 LTE bands [GSMA, 2022]
How effective is a copper-mesh Faraday cage against GSM, Wi-Fi and 5 G?
Copper with 0.5 mm apertures gives roughly 80 dB shielding at GHz ranges, enough to drop typical phone signals below usable strength [IEEE, 2021]. Users report no reception when mesh is grounded and fully enclosed [Elektroda, pdusp, post #18280894] Weak points are gaps around doors, cables and glazing.
What mesh size and material should I choose?
For 5 G up to 80 GHz, keep openings ≤0.5 mm; copper or tinned-copper offers high conductivity and easy soldering [Elektroda, pdusp, post #18280894] Stainless steel is cheaper but reduces attenuation by ≈10 dB [IEEE, 2021].
Do I need to ground the mesh?
Yes. Grounding drains induced currents and raises shielding by 20–30 dB [IEEE, 2021]. Connect every panel with conductive tape, then bond once to protective earth using 4 mm² wire.
How can I shield windows and doors?
Options: 1. Conductive window film (≈35 dB at 2 GHz) ["Shielding Film Datasheet"]. 2. Removable copper screen frames. 3. Replace glazing with metal-coated glass. All frames must contact the main mesh to avoid leakage [Elektroda, arekopo, post #17244717]
Is it legal to use a GSM/Wi-Fi jammer at home in Poland?
No. Polish Telecommunications Law forbids unlicensed transmitters; UKE can confiscate gear and fine up to PLN 1 million [UKE, 2023]. Similar bans exist in the EU and USA, where the FCC issues $112,500 penalties [FCC, 2023].
What health risks do high-power jammers pose?
A 3 W jammer raises local RF exposure above ICNIRP limits by up to 50 % within 1 m [ICNIRP, 2020]. "It will work like a solid microwave at home" [Elektroda, icosie, post #17244771] Long-term effects remain unclear.
Could blocking signals prevent emergency calls?
Yes. A cage or jammer stops all outgoing 112 calls; in a fire or medical crisis nobody inside can reach services [Elektroda, AdamC, post #17244909] This edge case makes total jamming risky in bedrooms.
Are router schedules a safer alternative?
Yes. Many home routers let you disable Wi-Fi for chosen devices on a timetable [Elektroda, piterek-23, post #17247086] That leaves cellular voice active while cutting late-night data.
How do I set a simple Wi-Fi curfew?
  1. Log into router admin and enable MAC filtering.
  2. Add the child’s device and set an 20:00–08:00 deny rule.
  3. Save, reboot router, and verify the phone loses Wi-Fi at 20:00 [Elektroda, piterek-23, post #17247086]
Which parental-control apps work without hardware changes?
Users recommend ESET Parental Control, Norton Family and KidsLox; they schedule access, block apps and send activity reports [Elektroda, VaM VampirE, #17244789; Elektroda, dusoft, #17245770].
What low-tech methods still work?
Collect the phone nightly, swap it for a non-smart "dziadkofon" feature phone, or fill evenings with books or hobbies [Elektroda, icosie, #17244750; Elektroda, robig, #17245973]. Consistent enforcement proved effective in multiple posts.
