How to un-Faraday a Faraday cage for double-blind research protocols
357 12
How can I introduce ambient RF signals into a Faraday cage for double-blind research without opening the enclosure?
Feed the outside signal into the cage with a linked antenna pair rather than a simple wire feedthrough: the working setup used two wide-band 20 MHz–2 GHz discone antennas, a low-power +10–12 dB wide-range amplifier (20 MHz–6 GHz), and the tent’s shielded sleeve to run the cable from the outside Rx antenna to the inside Tx antenna [#21675633][#21675635] The inside transmit antenna had to be placed at the center of the enclosure, beneath the pyramid apex, and kept on the floor to minimize hot/cold spots [#21675635] With that arrangement, FM stations that were normally blocked by the cage became receivable inside [#21675633][#21675635]
  • Wire feedthrough failed to reduce shielding efficacy
    #1 21675623
    Richard Knowles
  • Unground the cage to block EM waves
    #2 21675624
    Flix Cormier
  • Broadband 25 MHz–6 GHz signal relay idea
    #3 21675625
    Richard Knowles
  • Asking about frequency range and field uniformity
    #4 21675626
    richard gabric
  • #5 21675627
    Flix Cormier
  • 25 MHz–6 GHz target range and antenna placement concern
    #6 21675628
    Richard Knowles
  • Speculative ideas for weakening Faraday cage shielding
    #7 21675629
    Justin Spencer Mamaradlo
  • Exposed wire leaks only weak GSM and WiFi signals
    #8 21675630
    Richard Knowles
  • Speculation on AC voltage disrupting charge distribution
    #9 21675631
  • Shielded sleeve for cable feedthrough in Faraday enclosure
    #10 21675632
    Richard Knowles
  • Amplifier-enabled FM reception inside Faraday cage
    #11 21675633
    Richard Knowles
  • #12 21675634
  • Centering the Tx antenna improved reception inside tent
    #13 21675635
    Richard Knowles
A research group sought to introduce ambient electromagnetic (EM) radiation inside a Faraday cage without compromising a double-blind protocol by physically opening the enclosure. Initial attempts using a copper wire with exposed ends inside and outside the cage failed to reduce shielding effectiveness, as verified by an Icom IC-R20 radio scanner and smartphone signal tests. Discussions highlighted that grounding is not strictly necessary for Faraday cage shielding, and ungrounding the cage could allow EM penetration, though this was not applicable to their double-layered, grounded tent enclosure made by Holland Shielding. The group considered using repeaters with paired antennas inside and outside the cage, amplified by low-noise amplifiers, to relay signals across the shielding. Frequency range of interest was 25 MHz to 6 GHz, covering most cellular, WiFi, and FM bands. Concerns about spatial signal variability inside the cage due to constructive and destructive interference ("cold" and "warm" spots) were addressed by positioning the transmitting antenna centrally on the cage floor beneath the apex. The successful method involved using wideband discone antennas (20 MHz–2 GHz) connected via a shielded sleeve cable through the cage, with a Minicircuits ZX60-6013E+ low-noise amplifier (+10-12 dB gain) between the receive and transmit antennas. This setup enabled reception of normally blocked FM radio stations inside the cage. Future plans include extending this approach to higher frequencies (2–6 GHz) using microwave antenna pairs to achieve cellular and internet signal penetration inside the Faraday enclosure.
TL;DR: To “un‑Faraday” a cage, relay outside RF inside using a 20 MHz–2 GHz discone link and ~10–12 dB gain; “The trick… was to move the Tx antenna to the center.” [Elektroda, Richard Knowles, post #21675635]
Why it matters: Researchers needing double‑blind protocols can reproduce ambient EM conditions inside shielded enclosures without opening doors. This FAQ is for lab teams asking how to pass broadband RF into a Faraday tent while keeping protocols intact.
What does “un‑Faraday a Faraday cage” actually mean?
It means intentionally re‑introducing the outside ambient electromagnetic field into a shielded enclosure without opening it. The goal is to preserve double‑blind protocols while letting typical RF (broadcast, cellular, Wi‑Fi) exist inside for testing or human‑factors studies. [Elektroda, Richard Knowles, post #21675623]
Does a Faraday cage have to be grounded to block RF?
No. The thread reports effective shielding even when the enclosure was ungrounded. Grounding can manage static or shock risk, but RF attenuation of a well‑made conductive enclosure still occurs without a ground connection. [Elektroda, Richard Knowles, post #21675625]
What frequency range should I try to replicate inside?
A practical research target is 25 MHz–6 GHz. Very low frequencies (kHz, like AM broadcast) often penetrate large tents anyway, so teams focused budget and hardware on VHF through microwave where shielding is effective. [Elektroda, Richard Knowles, post #21675628]
What exact approach worked for bringing signals inside?
A pair of wideband discone antennas (20 MHz–2 GHz) linked through a low‑power wideband amplifier restored FM radio reception inside. The inside antenna was placed centrally to even the field. Quote: “We just used two wide‑band 20 MHz–2 GHz discone antennas.” [Elektroda, Richard Knowles, post #21675635]
Where should I place the inside transmit antenna to avoid dead zones?
Place the Tx antenna at the geometric center, on the floor under the tent’s apex. This minimized bright/dark spots likely caused by constructive and destructive interference within the cavity. “The trick… was to move the Tx antenna to the center.” [Elektroda, Richard Knowles, post #21675635]
Will a bare or semi‑insulated wire through the wall work?
A leaky wire acted as a poor antenna. It produced about one bar of GSM and Wi‑Fi inside, but calls and browsing still failed. Expect marginal coupling and unreliable service with this method. [Elektroda, Richard Knowles, post #21675630]
How do I build a simple outside‑to‑inside broadband RF link?
  1. Mount a wideband Rx antenna outside and feed it to a low‑noise wideband amplifier.
  2. Route the coax through the tent’s shielded sleeve to an inside Tx (wideband) antenna.
  3. Place the inside Tx at the center on the floor; verify with an FM radio or scanner. [Elektroda, Richard Knowles, post #21675635]
Can I use commercial cellular repeaters to cover the tent?
Standard cellular/Wi‑Fi repeaters are narrowband. The team avoided them because they wanted a broadband replica of the ambient spectrum rather than boosting only specific services. They chose wideband antennas and an amp instead. [Elektroda, Richard Knowles, post #21675625]
What is a discone antenna and why use it here?
A discone is a wideband omnidirectional antenna suited for scanning and broadband work. In this project, a 20 MHz–2 GHz discone pair provided broad coverage for relaying ambient RF into the enclosure with a single hardware set. [Elektroda, Richard Knowles, post #21675635]
Does the tent’s size and shape affect results?
Yes. The enclosure here was a double‑layer pyramid tent, ~11×11 ft base and ~7 ft tall. Its cavity behavior influenced interference patterns, making central placement of the Tx important for uniformity. [Elektroda, Richard Knowles, post #21675628]
Will near‑field effects make measurements position‑sensitive?
Yes. Inside a relatively small cavity, re‑radiated signals create near‑field and standing‑wave effects. Results can vary strongly with location, so plan for non‑uniform fields unless you optimize placement and power. [Elektroda, richard gabric, post #21675626]
Can the Faraday cage itself act as an antenna?
The idea was considered, using the cage or ground plate as a radiator, but it remained experimental and unproven in the thread. The author expected poor inside coupling from a hollow conductor acting as a transmitter. [Elektroda, Richard Knowles, post #21675632]
What results should I expect at very low frequencies like AM radio?
Large tents tend to leak very low frequencies. The team noted kHz‑range signals (AM) already came through, so they prioritized 25 MHz–6 GHz where shielding is stronger and replication is needed. [Elektroda, Richard Knowles, post #21675628]
Are there safety or grounding considerations during tests?
Ungrounded enclosures can accumulate charge and pose a shock hazard on contact. Grounding helps bleed charge, even though RF shielding still works without it. Plan safe handling and bonding procedures. [Elektroda, Richard Knowles, post #21675630]
What amplifier model was successfully used?
A Mini‑Circuits ZX60‑6013E+ was used between the outside Rx and inside Tx. It enabled clear FM station reception inside the tent, confirming the relay method. [Elektroda, Richard Knowles, post #21675633]
Why avoid moving the Tx antenna up toward the apex?
Raising the inside Tx toward the apex reduced performance in this tent. Keeping it centered on the floor improved uniformity and reception across the interior. [Elektroda, Richard Knowles, post #21675635]
