RF Signal Leakage in Faraday Cage Using Relcomm RDS-2S1D6 RF Relays Between 20MHz-6GHz
318 19
How can I stop ambient RF from leaking into a Faraday cage through an unpowered RF relay and its coax and power feedthroughs from 20 MHz to 6 GHz?
You cannot rely on the relay alone to block everything; the open-state attenuation is finite, so some leakage will remain, and the fix is to eliminate cable re-radiation by bringing all signal lines through proper bulkhead connectors at the cage wall and mounting the relay/amplifier directly there [#21676327][#21676331] Use a flat conductive plate bonded to the cage skin, with the coax connectors on that plate, so the coax shields are electrically bonded over their full circumference instead of running through the tent as a length of cable [#21676327][#21676334] Do the same for power and control lines: route them through wideband EMC filtering and feedthrough capacitors rather than plain wires, because otherwise they can pick up and re-radiate RF inside the enclosure [#21676327][#21676331] The thread specifically mentions Tusonix 4101 and 4209 parts as examples of the kind of feedthrough filtering needed for DC/control lines [#21676332] If you still see leakage, check every wire and cable path, because even shielded coax can act as an antenna if it is not terminated and bonded correctly at the enclosure boundary [#21676327][#21676334]
  • RF relay leakage still passes FM and 2.4 GHz signals
    #1 21676323
    Richard Knowles
  • Use a chassis connector with no coax inside the cage
    #2 21676324
    richard gabric
  • Shielded coax and power lines may be coupling RF into enclosure
    #3 21676325
    Richard Knowles
  • #4 21676326
    Richard Knowles
  • Need feedthrough capacitors and connector plate
    #5 21676327
    richard gabric
  • Requesting direct advice on cable shielding and grounding
    #6 21676328
    Richard Knowles
  • Recommend filtering mains and signal lines at the cage entry
    #7 21676329
    richard gabric
  • Need RF filtering for power and coax feedthroughs
    #8 21676330
    Richard Knowles
  • Use a conductive plate with feedthrough filtering
    #9 21676331
    richard gabric
  • #10 21676332
    richard gabric
  • Ground coax shields at tent entry point
    #11 21676333
    Richard Knowles
  • Bulkhead coax adapters for full-circumference grounding
    #12 21676334
    richard gabric
  • Need filter plates for BNC and SMA feedthroughs
    #13 21676335
    Richard Knowles
  • #14 21676336
    richard gabric
  • Cost-effective grounding plate and connector mounting question
    #15 21676337
    Richard Knowles
  • Need more detail on grounding plate and cage bonding
    #16 21676338
    richard gabric
  • Asking vendor about grounding plate materials and mounting
    #17 21676339
    Richard Knowles
  • Galvanized steel plates for Faraday tent grounding
    #18 21676340
    Richard Knowles
  • Recommend thinner sheet metal and smaller plate size
    #19 21676341
    richard gabric
  • Need to verify shielding integrity after grounding coax plates
    #20 21676342
    Richard Knowles
A project involves shielding a space from ambient electromagnetic (EM) radiation using a dual-layered, pyramid-shaped Faraday tent enclosure, operating between 20 MHz and 6 GHz. The setup includes two antenna pairs (20 MHz–2 GHz and 2–6 GHz) connected through a single sleeve port in the tent fabric, with Relcomm RDS-2S1D6 RF relays placed between the Rx (outside) and Tx (inside) antennas. The main challenge is preventing RF signal leakage through the sleeve and coaxial cables, which may have compromised shielding and grounding. Recommendations emphasize replacing the sleeve with a conductive bulkhead plate fitted with female-to-female connectors (BNC and SMA) to maintain shielding integrity. The RF relays and amplifiers should be mounted directly on these connectors at the cage wall to avoid coax cable leakage and re-radiation. Proper grounding of coaxial cable shields is critical, achievable only via connectors that electrically bond the outer conductor fully. Feedthrough capacitors and wideband EMC filters (e.g., Tusonix 4101 and 4209) are advised for power and control lines to prevent RF ingress. The Faraday tent manufacturer, Holland Shielding, confirms the need for filter plates and uses galvanized stainless steel plates with bolted or magnetic connections to the tent fabric for grounding. Cost-effective alternatives like galvanized grounding plates from hardware stores are considered but require careful evaluation of material properties, thickness, and mechanical support to ensure effective electrical bonding and maintain shielding performance. Final implementation includes mounting connectors and filters on a conductive plate clamped to the tent skin, with verification of shielding effectiveness after installation.
TL;DR: Expect ~80–90 dB relay off‑state attenuation; leakage remains unless you break cables at the shield with filtered bulkhead feedthroughs. “It’s not insertion loss you have to worry about, it is the off state attenuation.” [Elektroda, richard gabric, post #21676327] Why it matters: This FAQ shows how to stop unintended RF getting past relays into a fabric Faraday tent between 20 MHz and 6 GHz, fast.
Quick facts:
How do I stop RF leakage through an RF relay in a Faraday cage?
Treat the relay as imperfect isolation. Break every conductor at the shield boundary with a metal plate that holds RF bulkhead connectors and feedthrough capacitors. Filter DC and control lines across that plate. This preserves skin currents and prevents coax from re‑radiating inside the tent. Expect some residual through the relay, so the boundary treatment carries the load. “Use a very wide band filter… and cables must come through the skin via feed through capacitors.” [Elektroda, richard gabric, post #21676327]
What off‑state attenuation should I expect from RF relays like the Relcomm RDS‑2S1D6?
Plan for only finite isolation. The data sheets for similar relays indicate about 80–90 dB off‑state attenuation. That level still lets very strong outside signals create detectable leakage inside a sensitive environment. This is why relying on the relay alone is insufficient for a quiet cage. Quote: “the data sheets indicate 80–90dB.” [Elektroda, richard gabric, post #21676327]
Why does coaxial cable make my tent leaky, and what fixes it?
Lengths of coax can pick up and re‑radiate outside signals. If the shield crosses the tent skin continuously, it carries unwanted RF currents inside. Terminate that shield at a bonded bulkhead connector on a conductive plate. Mount relay and amplifier directly on the inside face to avoid any free cable acting as an antenna. [Elektroda, richard gabric, post #21676327]
Sleeve vs. bulkhead: what should pass through the tent wall?
Use a chassis bulkhead adapter, not a fabric sleeve. Bulkheads bond the shield over 360° to the cage wall, confining circulating currents to outside or inside circuits. Then bolt the relay and amplifier directly to that connector on the inside. Avoid any coax runs through the skin. [Elektroda, richard gabric, post #21676324]
How should I bring DC power and control lines into the cage?
Install wideband EMC filters and feedthrough capacitors on a bonded plate at the wall. Select parts covering your band of interest. Named examples used in practice include Tusonix 4101 and 4209 series. Watch switch‑mode supplies; they can radiate in the tens of MHz and must be filtered at the boundary. [Elektroda, richard gabric, post #21676332]
Do I need a conductive plate on a fabric Faraday tent?
Yes. A rigid conductive plate provides a low‑impedance, repeatable bond for bulkhead RF connectors and feedthrough filters. Clamp or bolt the plate through the tent’s metallized fabric with a mating plate and gasket to maintain shielding integrity under mechanical load. [Elektroda, richard gabric, post #21676331]
What is a bulkhead/chassis RF adapter?
It’s a female‑to‑female connector designed to mount in a conductive panel. It bonds the coax shield across the wall with 360° contact. This breaks the cable at the boundary while maintaining the shield path on both sides, preventing shield currents from crossing the skin. [Elektroda, richard gabric, post #21676324]
What is a feedthrough capacitor?
A feedthrough capacitor is a three‑terminal filter that passes DC while shunting RF to the bonded panel. Mount it in the conductive plate so the body bonds to the plate and the line passes through, giving strong RF attenuation into the cage. [Elektroda, richard gabric, post #21676327]
What’s the insertion loss of the RDS‑2S1D6, and does it matter here?
Reported insertion loss is about 0.1 dB, which is small for pass‑through operation. However, leakage complaints in this thread arise with the relay open, where insertion loss is irrelevant. Address isolation at the boundary and cable management first. [Elektroda, Richard Knowles, post #21676325]
Can exposed metal cases re‑radiate and cause contamination?
Yes. Any conductive object can act as an antenna if the connected circuitry supports it. Enclosures for relays and amplifiers should be bonded to the plate at the boundary. Keep leads short and avoid floating metal inside the tent. [Elektroda, Richard Knowles, post #21676325]
What frequency ranges should I design my filters and interfaces for?
Design boundary filtering and bonding for 20 MHz to 6 GHz. The tent becomes progressively transparent below about 20 MHz, so your filter choices and tests should focus on 20 MHz and up. Use components specified across that span. [Elektroda, Richard Knowles, post #21676330]
Is a store‑bought grounding plate a safe substitute for vendor filter plates?
Be careful. Plates intended for earthing rods may not provide the required conductivity, surface finish, or stable long‑term bond to metallized fabric. The shielding properties depend on that bond quality. Verify materials, finish, and clamping method first. [Elektroda, richard gabric, post #21676338]
How can I diagnose where the leakage is coming from?
Check three paths. One: power and control lines lacking wideband feedthrough filters. Two: coax shields crossing the skin without bulkheads. Three: re‑radiation from lengths of cable acting as antennas. Fix each at the boundary, then retest. [Elektroda, richard gabric, post #21676327]
What’s the fastest way to retrofit a fabric tent with proper pass‑throughs?
Try this 3‑step plan:
  1. Add a small conductive plate pair that clamps through the fabric near the port.
  2. Install BNC/SMA bulkhead connectors and feedthrough capacitors in that plate.
  3. Mount relay and amplifier directly on the inside face; eliminate loose coax lengths. [Elektroda, richard gabric, post #21676331]
Will a single connector plate handle mixed RF and power pass‑throughs?
Yes. Use one compact plate to host RF bulkheads and DC/control feedthrough filters. Keep it mechanically supported if heavy. Plan connector spacing so short jumpers reach the relay and amplifier without slack that could radiate. [Elektroda, richard gabric, post #21676331]
Why won’t the relay alone solve Wi‑Fi and FM leakage?
Because the relay isolation is finite and strong ambient signals exist. Wi‑Fi at 2.4 GHz and FM broadcast can leak via shields and unfiltered lines. Boundary bonding and filtering provide the missing attenuation beyond the relay’s limit. [Elektroda, richard gabric, post #21676327]
