[Solved] Baofeng UV-5R Setup & Operation: Step-by-Step Guide for Emergency Services Frequencies in Zamość
tgbyhn638 58422 33
How do I configure a Baofeng UV-5R step by step to receive emergency-service frequencies in Zamość, including the correct band, channel spacing, squelch, scanning, and antenna setup?
To listen to services, tune the UV-5R to the exact frequencies used in your area rather than simply selecting 144 MHz; the thread identifies 2 m as the 144 MHz band, while local listings mentioned 169.100 MHz and 168.625 MHz. Enter each frequency into a separate memory channel, save the channels, and then scan the programmed memories; for troubleshooting, select a frequency directly and set squelch to its minimum rather than scanning immediately [#17247788] [#17248519] [#17248616] The radio’s transmit-power setting (TXP) is not SWR, and SWR matters for transmitting rather than receiving [#17248325] Reception may improve substantially with a good, elevated antenna and cable; the supplied short antenna can still work depending on location, but a J-type or other suitable 2 m antenna was recommended for fixed listening [#17248192] [#17248995] Receive only: transmitting on 2 m requires a license, and the thread warns that unauthorized broadcasting is punishable [#17248248] [#17248325]
  • #31 17254489
    karlosik
    Rate: 17
    Did the colleague finally picked up something with this radio which, according to him, looked like the service?
  • #32 17260692
    tgbyhn638
    Rate: 28
    Yes, I just picked up the radio today, it works elegant, good range on this 40cm antenna. Something was exclusive, set up, and it's supposed to work. If anyone is interested, I can find out more or less how he did it and about this device in general
  • #33 17273521
    Gagatek77
    Help: 18
    Did your colleague manage to receive any messages that he cared about?
  • #34 17314442
    tgbyhn638
    Rate: 28
    It worked, I am very happy, you can hear everything and the 30cm antenna works. I do not compare to the one made, but this one also works.
The discussion revolves around setting up and operating the Baofeng UV-5R radio for listening to emergency services frequencies in Zamość. Users emphasize the importance of using a suitable antenna, with suggestions to replace the stock 40 cm antenna with a homemade "J" type or a Yagi antenna for improved reception. The conversation includes step-by-step guidance on programming frequencies, setting the radio to the 2m band (144 MHz), and adjusting squelch settings. Users also highlight the necessity of a programming cable for easier configuration and the legal implications of broadcasting without a license. Overall, the community provides practical advice and resources, including links to instructional videos and frequency tables for local emergency services.
TL;DR: A tuned 2 m J-pole antenna can raise received signal strength by up to 6 dB [ARRL], and “without a proper antenna you will not catch too much” [Elektroda, adversus, post #17247977] Program the 168–170 MHz Zamość service channels into UV-5R memory, use 12.5 kHz steps, set squelch low, and scan. Transmitting there is illegal.
• Frequency coverage: 136–174 MHz / 400–520 MHz (UV-5R spec) [Baofeng Manual]. • Receive sensitivity: 0.2 µV for 12 dB SINAD [Baofeng Manual]. • Licence-free transmit only on 446.0–446.2 MHz PMR, ≤0.5 W ERP [UKE Regulation 2022]. • USB programming cable costs approx. €4–€8 [Allegro listings 2023]. • DIY 2 m J-pole materials <€5 [Elektroda, adversus, post #17248995]
Which exact frequencies do emergency services use around Zamość?
Public lists show 168.625 MHz and 169.100 MHz for medical and fire dispatch in Zamość [Elektroda, tgbyhn638, post #17248538] Program both with 12.5 kHz steps.
How do I switch the UV-5R to the 2 m (144 MHz) band?
Press VFO/MR to VFO mode, enter 144000, then press MENU → 27 (BAND) → CONFIRM. The display now shows 144.000 MHz, placing the radio in the 2 m band [Elektroda, adversus, post #17248424]
What are the three key steps to store a channel?
  1. In VFO mode, type the frequency (e.g., 168.625).
  2. MENU → 27 (MEM-CH) → select an empty number → CONFIRM.
  3. Exit with EXIT. The frequency is now in memory [YouTube Demo 2018; Elektroda, tgbyhn638, #17248478].
How do I activate scanning through saved channels?
Hold SCAN button for two seconds in MR mode. The radio cycles through programmed memories until it detects a signal. Stop with any key [Elektroda, adversus, post #17248519]
Which antenna gives the best indoor reception for services?
A ½-wave J-pole hung near a window increases signal up to one S-unit (≈6 dB) over the 40 cm whip [ARRL]. Users report clear service traffic after installing it [Elektroda, adversus, post #17247788]
Can I legally transmit on these frequencies?
No. Polish law restricts 2 m service channels to authorised users. Only PMR446 channels (446.0–446.2 MHz, 0.5 W) are licence-free [UKE Regulation 2022; Elektroda, adversus, #17248265].
Is a USB programming cable worth buying?
Yes for multiple radios. It blocks transmit, labels channels, and saves time. Cost is €4–€8 and avoids accidental keying [Elektroda, dktr, post #17249567]
Why might I hear only one side of a conversation?
Services often use repeaters with separate uplink/downlink. A weak antenna may reach the base station but miss mobiles, causing half conversations [Elektroda, adversus, post #17247977]
What reception range can I expect with better antennas?
Users report 10–15 km with a balcony-mounted copper-pipe J-pole and up to 30 km with an 8-element tape-measure Yagi aimed line-of-sight [Elektroda, Radiokiller, post #17249049]
How do I build the tape-measure Yagi mentioned in the thread?
  1. Cut five 16 mm wide steel tape-measure elements to 50 cm, 45 cm, 40 cm, 45 cm, 50 cm.
  2. Mount on a 1 m PVC boom at 38 cm spacing.
  3. Feed the driven element with 50 Ω coax via a simple gamma match. “The antenna received ISS SSTV at 4° elevation” [Elektroda, Radiokiller, post #17249077]
