Stag 4 Gas Installation Issue: Not Switching to Gas, Possible Sensor/Cable Damage?
mcmat 8646 4
  • #1 17171286
    mcmat
    Hi. I have a problem with the Stag 4 gas installation. I do not hear a characteristic puff from the back (valve opening), the diode flashes green slowly (theoretically waiting for the engine temperature). However, after pressing the B / G button under the hood, the injectors are activated (probably, because you can hear them). The gas is full, the lights show good condition.
    Could it be a serious problem or e.g. damaged temperature sensor or cables?
  • #2 17171430
    przemek25l
    Help: 124
    Rate: 372
    Temperature sensor as possible.
    But to check it carefully, you should connect the computer and see. Because this is an eye diagnosis.
  • #3 17171461
    kowal5
    Help: 25
    Rate: 69
    Also check whether the reducer is warming up. Whether there is air in it.
  • #4 17185960
    psooya
    Help: 376
    Rate: 575
    No RPM or proper temperature.
  • #5 17195726
    ving
    Rate: 20
    I had a similar problem once. The reason was a damaged wire next to the volatile gas temperature sensor
