[Solved] Scenic 2 1.6 16v: Removing Alternator - Unscrewing Bumper, Step-by-Step Guide
Janusz 2102 13488 7
  • #1 17254252
    Janusz 2102
    To remove the alternator I have to unscrew the bumper
  • #2 17254403
    decybel91
    Help: 1024
    Rate: 4231
    Sometimes even the front beam two lamps and move the coolers away.
  • #3 17254648
    kamiloskop
    Help: 42
    Rate: 279
    Without exaggeration comes out without removing the bumper just have fun. You must unscrew the belt guide roller because under it there is a screw from the alternator.
  • #4 17255259
    decybel91
    Help: 1024
    Rate: 4231
    can you describe how you get it
  • #5 17255277
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Okay, start from this moment when you have the generator and cables unscrewed. The very act of pulling us is of interest.
  • #6 17255434
    kamiloskop
    Help: 42
    Rate: 279
    The engine on the lift, engine cushion discarded, the engine against the bulkhead wall pushcharts and there is room. Well gentlemen, please do not write that the bumper do you remove to the alternator output ws ii?
  • #7 17255750
    decybel91
    Help: 1024
    Rate: 4231
    It is still tight, especially in 1.9dci. The bumper in Scenic2 is just 3min literally loosening, so there is no harm.
  • #8 17282977
    Janusz 2102
    disassembly of the front lamp bumper and metal beam and the alternator removed.
The discussion revolves around the process of removing the alternator from a Renault Scenic 2 1.6 16v. Several users suggest that it is possible to remove the alternator without unscrewing the bumper, emphasizing that the belt guide roller must be unscrewed to access a screw securing the alternator. Some users mention that while it can be tight, especially in the 1.9 dCi model, loosening the bumper takes only a few minutes and may simplify the process. The conversation includes various methods and tips for disassembly, including the need to move front lamps and coolers for better access.
